RUG/Pennsylvania/State College/Solidworks OHM
Overview
The Open Hybrid Mendel (or OHM) is a project of the State College Reprap Users Group. It is a Mendel design, which uses both standard Sells Mendel parts, a Prusa Z drive, various redesigns from the community at large, and a number of small design improvements developed in our PSU Reprap class. It is so named due to this hybridization of designs, and obtains the 'Open' designation from the OpenX and OpenY axes it uses. The prototype for the OHM design was Etherdais_Unit_One. On this page there are the sub-assemblies and full assembly of the most up to date OHM design done on SolidWorks. Under each sub-assembly and the final assembly there are screen pictures and zip-files for all the parts. So be prepared because you now have the power to create your very own OHM!
Files
This is a table of all of the packed Solidworks assemblies and 3D PDFs for each subassemblies. A 3D PDF is a [universal 3D file] that will allow any user to view a 3D model without a specialized 3D modeling software. To view these files, you may need to save the PDF to your computer to open it rather than view it in your browser. The full assembly is too large to effectively view in a 3D PDF, so this file is not available at this time.
Assembly | Solidworks Zip File | 3D PDF |
Full OHM | Media:Ohm solidworks assembly.zip | n/a |
Frame | Media:Frame assembly.zip | Media:Frame_Assem_pdf.PDF |
Z Axis | Media:Z-axis.zip | Media:Z-axis_pdf.PDF |
X Axis | Media:X-axis.zip | Media:Xaxis_pdf.PDF |
Bed/Carriage | Media:Bed_assembly.zip | Media:Bed_carriage_assem_pdf.PDF |
Extruder | Media:Extruder.zip | Media:Extruder_Assembly_pdf.PDF |
Full Assembly
This is the full assembly in SolidWorks. Each subassembly is represented by a different color of printed pieces.
Above are SolidWorks pictures of the full assembly. Below is the zip file containing all parts and hardware:
Media:OHM_Assembly.zip
Subassemblies
Though all parts work together to make a 3D model somewhat like a human body; we broke the assembly down to five sub-assemblies.
Frame
The OHM uses Camiel's thin shelled Vertex design, maintaining vertices similar to the Sells design, but using less filament. The frame has one motor that powers a belt to move the bed in the y-axis. It uses threaded rods to connect the vertices and is the same as the original Mendel design.
Above are SolidWorks pictures of the frame assembly. Below is the zip file for this assembly:
Z Axis Assembly
The OHM uses a Prusa double motor design for driving the Z axis, avoiding the large prints and continuous belt of the Sells Z-drive design. We still use Sells bar clamps to clamp the smooth rod to the Z-motor mounts, as they are compatible, and look sharp together.
Above are SolidWorks pictures of the z-axis assembly. Below is the zip file for this assembly:
Media:Z-axis.zip
X-Z Axis Assembly
Currently, the OHM build uses something like a standard Sells X-Z assembly, as described here in Mendel_X-axis. An important change in the design of the assembly is to be noted. The x vert drive side plate 360 end is no longer being used for future RepRap parts. A modified version of the 360 end is being used. This piece is longer and doesn’t require a spacer piece. This allows for adjustment as well as a better belt configuration that reduces stress.
Above are SolidWorks two pictures of the x-z axis assembly. Below is the zip file for this assembly:
Media:X-axis.zip
X-Axis Vertical Bearing Assembly Guide
For parts list refer to Mendel x-axis Vert bearing 180
In some cases, though it is not necessary, it may help if you drill out the holes before assembling.
First, assemble the x-vert-drive-nut-trap_4off. To do this, you need a lighter, four m4 nuts and a m4x40-cap. Place an m4 Nut on the end of the m4x40-cap and heat with the lighter. Caution: Do not heat for too long or the m4x40-cap will become very hot.
Push the heated nut into one of the hexagonal holes in the x-vert-drive-nut-trap_4off. Repeat for all four nuts.
Screw x-vert-drive-side-plate-180-end_2off and x-bar-clamp-m4_4offtogether using m4x40-cap and washers. Do not screw them all the way in.
Screw x-vert-drive-nut-trap_4off into x-vert-drive-side-plate-180-end_2off using a diagonal pattern. Remember to use washers. Do not screw them all the way in.
Repeat previous steps to create other half. Make sure that you place the screws diagonally in a way that they do not interact with the other screws.
Place the x-vert-drive-nut-trap_4off in between the bottom half of the two sides and line up screws. Screw in the M4 screws until they sit in the nuts and are firmly in place. This could take some adjustment.
Place an M8 nut in between the two trap sides. Then screw the upper screw together. Tighten all screws in steps.
Y Bed Carriage
The OHM uses a modified OpenY, with an optoless belt harness, and a second 90/180 arm in place of the 90/270 arm. This demands two additional bearings, but we find the result is more stable, while retaining the benefits of the OpenY. A modified Sells y-motor bracket is used, which avoids printing an unused endstop holder from the original Sells design. The original Sells y-bar clamps seem well suited for mounting y-axis opto-endstops.
Above are SolidWorks pictures of the y bed carriage assembly. Below is the zip file for this assembly:
Extruder and Carriage
We are in the process of finding a design which is more compatable with the TechZone steel hot tips we've been using recently, though the current design is a hack of herringbone extruder gears, and GregFrost's hinged wades extruder.
Above are SolidWorks pictures of the extruder and carriage assembly. Below is the zip file for this assembly:
Media:Extruder.zip
