RUG/Pennsylvania/State College/Universal Paste Extruder
Revision as of 19:53, 15 April 2014 by Jlm5940 (talk | contribs) (Components)
Overview
This page is dedicated to providing detailed information on how to build and use a universal paste extruder. These types of extruders are becoming more and more popular as can be seen in the media timeline.
Types of Materials That Can Be Used
Ceramics
Dough
Cake
Icing
Chocolate
Sugars
Related Projects and Results
Below are details about paste extrusion projects that have been completed by students using this extruder.
Name Students Link Description
Components
Name Quantity Supplier Link Files Price
Gear and drive set (small gear, medium gear, large gear, idler block, syringe pressure block 1 http://www.thingiverse.com/thing:20733/ Gear and Drive Set n/a
Plastic Body V2 Extruder 1 http://www.thingiverse.com/thing:20733/ http://www.thingiverse.com/download:64989 n/a
NEMA17 motor 1 http://www.omc-stepperonline.com/nema-17-unipolar-stepper-031a-158ncm224ozin-17hs130316s-p-65.html n/a $10.76
T5 10teeth Metal drive Gear 1 http://www.thingiverse.com/thing:20733/#files http://www.thingiverse.com/download:65633 n/a
624 Bearings 4
608 bearing 1
20mm M8 Smooth rod 1
55mm M4 Bolt 1 Home Depot http://www.homedepot.com/p/Unbranded-M4-0-7-x-55-mm-Stainless-Pan-Head-Phillips-Metric-Machine-Screw-2-Pack-12468/203540123 $1.76/2 pack
75mm M4 bar or bolt 1
M4 Hex spacer (or M4 wingnut) 1
M4 plain nuts 2
M4 Nylock nuts 4
M3 Nuts 6
20mm M4 bolts 2
10mm M3 bolts 5
M3 washers 14
45mm M3 bolts for Idler 2
springs or Silicon pressure spacers for Idler 2
small zip tie 1
5-6mm wide T5 belt ~about 40cm 1
Plastic sheet 1
Assembling
Generating the Gcode and Printing
Slic3r (http://slic3r.org) can slice a CAD file into G-code for the paste extruder. It requires specific settings:
  • Open Slic3r
  • Click "Preferences" and select "Expert" from the drop-down menu next to "Mode"
  • From the "Print Settings" tab:
    • Layers and perimeters:
      • Set the "Layer Height" to the right value (this value depends on the paste, and must be determined through experimentation, usually about equal to nozzle diameter)
      • Set "First Layer Height" to 80% of Layer Height
    • Infill:
      • Change "Fill Density"
        • Higher density will obviously take longer, but is better for parts that actually function.
    • Speed:
      • Speed for print moves"
        • all the values should be identical, and equal to the printing speed determined through experimentation (it depends on the paste, the nozzle and the pressure)
        • The speed for non-printing moves can be left to its default value
      • Modifiers:
        • Set the "First layer speed" to 100%
    • Output options
      • Download the perl script to turn extrusion commands into fan commands (Paste-perl.zip), and place it in any folder (don't forget to un-zip it). Then add its absolute path to the post-processing frame. On Unix, open the terminal and run the command "chmod 755 /path/to/the/script". Make sure that there aren't any white-spaces in the script's path (it may result in a crash). On Windows, you need to download and install a Perl interpreter: http://www.perl.org.
    • Advanced:
      • Set the "First layer" to 100%
  • From the "Filament Settings" tab:
    • Cooling:
      • Enable:
        • Disable both options (fan always on and auto cooling)
  • From the "Printer Settings" tab:
    • General:
      • Firmware:
        • Set the "G-code flavor" to MakerWare (MakerBot)
    • Extruder 1:
      • Size:
        • Set the "Nozzle diameter" to the right value (depends on the printer)
      • Retraction:
        • Set the "Length" to 2 (disabling it provokes a bug)
The post-processing script used turns the extruding commands into fan commands. If you plug the solenoid valve on the fan port, you won't need to re-flash the printer. Note that if you don't re-flash it, since there is a temperature security, you must left the regular extruder's thermocouple or thermistor plugged (considering that you took a working printer and replaced the extruder).
In order to determine the right values (this hasn't been done yet, and must be followed with caution):
  • The layer height is close to the height of a printed paste line.
  • The nozzle size shouldn't be set to the actual nozzle size, but rather to the printed paste line width.
  • The speed depends on the nozzle size, the viscosity of the paste and the air pressure. Try to find values that result in a good print for these 4 parameters (including speed).
