RUG/Pennsylvania/State College/Vertex Param
Revision as of 20:16, 22 March 2012 by KtripPSU (talk | contribs)
How to Parametrize Mendel vertices to vary machine height... I think
It's time for a new project, and therefore a new project blog. The goal of this undertaking is to develop an OpenSCAD script that allows the user to vary the angles incorporated into the design of the base vertices for our printers. But what's the purpose? By making the angles larger, it will allow us to increase the printable height of the machines, offering yet another greater degree of freedom in our design. I'm hoping to start with existing code, but I may just steal parts from that or even write my own if it turns out to be easier.
Progress Blog
3.22.12
Project inception: Eric and Dave gave me the idea, and I decided to run with it.
Found this, it's a basic vertex written in SCAD, but seems like a bit of a pain to deal with. I think I'll just pull some of it's dimensions for reference, but just start with my own fresh code instead.
I was able to model the basic ends, but decided on an even better basic design. Rather than using the basic block-style structure, a swept arc could be used to create the basic structure. Not only is this easier to get stared with the coding, the parametrization will be much simpler and more fluid. I may try both designs and then just see which one looks/performs better. Anyways, that's all in the future. Here's what I got done today with the OpenSCAD code. Enjoy!
//Parametrization of Vertices
//Kevin Trippel
m8 = 9.9;
m8wide = m8 + 3;
heights = 13.9;
//Create basic shape for ends
difference(){
linear_extrude (height = heights) polygon(points = [[9,0],[0,9],[0,21],[9,30],[29,30],[29,0]], paths = [[0,1,2,3,4,5]]);
linear_extrude (height = heights) polygon(points = [[9,2],[2,9],[2,21],[9,28],[27,28],[27,2]], paths = [[0,1,2,3,4,5]]);
rotate([90,0,0]) translate ([20,heights/2,-30]) cylinder(h = 350, r = m8/2, center = false);
//Begin Structural Components
//Horizontal Cross-member
difference(){
translate ([0,13.5,0]) cube(size = [29,3,heights], center = false);
rotate([90,0,0]) translate ([20,heights/2,-29.5]) cylinder(h = 30, r = m8wide/2, center = false);
translate([7,15,0]) cylinder(h = heights, r = m8/2, center = false);
//Bottom
difference(){
linear_extrude (height = 2) polygon(points = [[9,0],[0,9],[0,21],[9,30],[29,30],[29,0]], paths = [[0,1,2,3,4,5]]);
//Vertical Cylinder
difference(){
translate([7,15,0]) cylinder(h = heights, r = m8wide/2, center = false);
//Vertical Cylinder Gusset
difference(){
translate([0,8.65,0]) cube(size = [7,12,heights], center = false);
//Horizontal Cylinder
difference(){
rotate([90,0,0]) translate ([20,heights/2,-30]) cylinder(h = 30, r = m8wide/2, center = false);
rotate([90,0,0]) translate ([20,heights/2,-30]) cylinder(h = 30, r = m8/2, center = false);
//Horizontal Cylinder Gusset
difference(){
translate([20-(m8wide/2),0,0]) cube (size = [m8wide, 30, heights/2], center = false);
