RUG/Pennsylvania/State College/gold
This page is for information about the PSU Unit Gold, which is under construction. This unit will follow the design of the Ohm 9.3. All of the printable parts were printed in PLA and assembled. Started from January, 2013. Four Gold team members, Yande Liu, David Blyton,Carina Chu and Edger built most of the Printer. The Frame of the printer has been finished, All the electronic parts have been finished. The only things left are the open-x.
Operating Specifications
Operating Specifications | |||||||
Name | Status | Design | Electronics | Firmware | Extruder | Temperature | Comments |
Silver | Working | Ohm | RAMPS | [RAMPS v1.4] | Not included | Undetermined | Need to be finished. |
Works in Progress
Parts needed:
Main Gear and small gear on the extruder. Tip. Thermal couple. Temperature censor unit.
Works need to be done
All the electronics need to be connected. Three end stop need to be mounted. The arduino board should be mounted on to the frame. Open-X need to be assembled. Thermal couple and temperature censor need to be mounted. All the parts need to tested. The bed needs to be leveled.
Builders
Frame: Yande, Carina, David, Edger
Electronics: Yande
