Re-ARM
Revision as of 18:53, 7 August 2017 by BobKuhn (talk | contribs) (Created page with "{{Re-ARM}} {{Languages|Re-ARM}} {{Development |image = |status = Working |name = Re-ARM |description = LPC1768 for use with RAMPS 1.4 |license = GPL |author = Bob Kuhn ...")
Template:Re-ARM
Re-ARM
Release status: Working
[[image:|center|190px]]
Summary
UNDER CONSTRUCTION
Re-ARM is a R3 form factor NXP LPC1768 based controller. It is meant to replace an Arduino mega260.
Software
Smoothieware - see xxxx for a useable configuration
Marlin - under construction - will be supported in Marlin 2.0
Compatible Shields
RAMPS1.4 is the only known compatible shield.
RAMPS-FD has an interference problem.
Pinout when used with RAMPS1.4
The LPC1768 has fewer I/O pins than the mega2560 which results in some logical pins no longer available and some logical pins being available on two different pins.
The logical pin numbers in the gallery are Marlin.
