RePlex
Description | Acrylic Prusa
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
It will soon be describing the Lasercut plexyglass (PMMA/acrylic) RepRap "RePlex"
Design by Olivier Grossat & Eolipyle Association eoliyple.frWe started presenting the RePlex 3D Printer projet in "Carrefour des Possibles" in Centre 104 in Juin 2012. RePlex has also been used in ESA, Ecole Spéciale d'Architecture during 2 school years in order to initiate students to the rapid prototyping methods. One RePlex has been reproduced by ESA's students.
Within Eolipyle Association, we have been testing with several materials, but the acrylicis the most designful, laser cuttable & also solid one.
The current RePlex is designed & realized in PMMA, beacause we do believe that PMMA 3D Reprap is a great choice for following reasons :
- The pieces are lasercutted rapidly
- Quick & easy assembly, each part can be easily replaced in case of breakage
- No use of toothed belt
- The innovative double rack system (x, y) prevents the space between the rack and the toothed wheel
Still we recommend verifying the Lasercut laser beam perfect verticality on a small test (cutting a square, watch the edges must be perfectly vertical): if not the parts may not fit together.
FAQ :
-Q Why not Polycarbonate (PC) instead of PMMA ? (Yeeazzz : Bullet proof 3D Printer !)
-A Despite the fact i wouln't like to be shot, with or without a printer in my arms, it was a very common problem of price
Also for some reason the LaserCut we had access to didn't supported Polycarbonate cutting, please send us some news if you tried it !
Working Notes. This is a stub!
Everything below this point is working notes. Here is a basic photo example, which is resized to 400 pixels wide, and on the left hand side of the screen.
Here is the Mediawiki code to make that: [[Image:example.jpg|left|400px|This is 400 pixels wide, and on the left.]]
Forum thread?
AI
http://eolipyle.fr/images/replex/plan01.ai
http://eolipyle.fr/images/replex/plan02.ai
DXF
http://eolipyle.fr/images/replex/plan01.dxf
http://eolipyle.fr/images/replex/plan02.dxf
Image Example
Related Projects
Text text text text New Example. Another Example text text text text text text text text.
Files and Parts
Sub Assemblies and Related
Text text text text Example/SubAssembly and Related Example text text text text text text text text text text text text text text text.
Downloads
- File:Uploaded files example.zip
- File:Even more example files.zip
- File:Example part.stl
- File:Other example part.stl
Photos and Drawings
Links can be put in captions.
More Examples
Huge Image
Text text textTo insert a video from Vimeo, just insert the code below, and use the number after http://vimeo.com/ <videoflash type="vimeo">5202148</videoflash>
For Youtube you use the following format, you get the video's address by looking at the video in youtube, you need the part between the "=" and the "&" so this video has the address "youtube.com/watch?v=2FU0v-3gloo&feature=player_embedded", you need the bold part. Get it? <videoflash type="youtube">Hl4Gf5R4YJg</videoflash>
