RepRapBox
Revision as of 15:14, 8 February 2015 by AndrewBCN (talk | contribs) (Created page with "This is exactly the same project as the OctoGoatBox except we are not going to run OctoPrint as our 3D printer web frontend, instead we are going to use a newer server sof...")
This is exactly the same project as the OctoGoatBox except we are not going to run OctoPrint as our 3D printer web frontend, instead we are going to use a newer server software called RepRapWeb by Andrew Hodel.
Andrew provides a ready-to-install SD card image for the Raspberry Pi, however the same reservations I had about running OctoPrint on the RPi apply here (basically, lack of processing power when using the older single-core 700MHz armv6 RPi's; the newer RPi 2 is a much more capable machine and should be able to run either RepRapWeb or OctoPrint just fine, but I have not tried it yet).
