RepRapDiscount Full Graphic Smart Controller
Revision as of 10:25, 6 May 2013 by RUMBA dancer (talk | contribs) (added direct link to open source files in reprapdiscount forum)
RepRapDiscount.com Full Graphic Smart Controller
Run your RAMPS without a computer just with a SD card!
GPL
Electronics
Based on bkubicek idea and STB's DOGM128 implementation, we realized this full graphic smart controller.
This full graphic Smart Controller contains a SD-Card reader, an rotary encoder and a 128 x 64 dot matrix LCD display. You can easy connect it to your Ramps board using the "smart adapter" included.
After connecting this panel to your Ramps you don't need your pc any more, the Smart Controller supplies power for your SD card. Further more all actions like calibration, axes movements can be done by just using the rotary encoder on the Smart Controller. Print your 3D designs without PC, just with a g-code design stored on the SD card.
Schematics
LCD Connect Schematics
RepRapDiscount Full Graphic Smart Controller Schematics
Smart Adapter Gerber Files
RepRapDiscount Full Graphic Smart Controller Gerber Files
As firmware we used Marlins' sources, to update the firmware in the future you just need an Arduino board, so you are good to go ;)
Pictures of a Full Graphic Smart Controller made by RepRapDiscount.com
Marlin V1 (new)
In "Configuration.h”
  1. Change “#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER” (just remove the // at the beginning)
Upload the firmware, power off the Arduino, connect the panel, reapply power, and everything should work.
Open Source Files
You can find the open source files here: http://forum.reprapdiscount.com/forums/oss/
Where to get it?
If you don't have the mood to build it yourself you can just buy one worldwide here
All parts are licensed under Attribution - ShareAlike.
