RepRapFirmware
Revision as of 15:26, 19 January 2015 by Glenn (talk | contribs) (+ Category:Firmware)
Introduction
This firmware is intended to be a fully object-oriented highly modular control program for RepRap self-replicating 3D printers. It owes a lot to Marlin and to the original RepRap FiveD_GCode.
Source code:
 https://github.com/reprappro/RepRapFirmware
This is the version for the RepRap Duet (Atmel SAM3X8E based, 32-bit ARM Cortex-M3 RISC processor):
 http://blog.think3dprint3d.com/2013/12/Duet-Arduino-Due-compatible-3DPrinter-controller.html
A complete uploadable executable version is in the directory Release/RepRapFirmware.bin in the above repository. For details of how to flash it to a Duet see here:
 https://reprappro.com/documentation/ormerod/maintenance/#RepRapPro_Firmware
Variants
The main branch, supported by RepRapPro and linked above as source code, is maintained by Adrian Bowyer. There are also other versions, notably those developed by RRP Ormerod owners:
dc42 - https://github.com/dc42/RepRapFirmware
zombiepantslol - https://github.com/zombiepantslol/RepRapFirmware
Usually these are discussed in the Ormerod forum: http://forums.reprap.org/list.php?340
General design principles
  • Control by RepRap G Codes. These are taken to be machine independent, though some may be unsupported.
  • Full use of C++ OO techniques,
  • Make classes hide their data,
  • Make everything except the Platform class (see below) as stateless as possible,
  • No use of conditional compilation except for #include guards - if you need that, you should be forking the repository to make a new branch - let the repository take the strain,
  • Concentration of all machine-dependent defintions and code in Platform.h and Platform.cpp,
  • No specials for (X,Y) or (Z) - all movement is 3-dimensional,
  • Except in Platform.h, use real units (mm, seconds etc) throughout the rest of the code wherever possible,
  • Try to be efficient in memory use, but this is not critical,
  • Labour hard to be efficient in time use, and this is critical,
  • Don't abhor floats - they work fast enough if you're clever,
  • Don't avoid arrays and structs/classes,
  • Don't avoid pointers,
  • Use operator and function overloading where appropriate.
Naming conventions
  • #defines are all CAPITALS_WITH_OPTIONAL_UNDERSCORES_BETWEEN_WORDS
  • No underscores in other names - MakeReadableWithCapitalisation
  • Class names and functions start with a CapitalLetter
  • Variables start with a lowerCaseLetter
  • Use veryLongDescriptiveNames
Structure
There are six main classes:
  • RepRap
  • GCodes
  • Heat
  • Move
  • Platform, and
  • Webserver
RepRap
This is just a container class for the single instances of all the others, and otherwise does very little.
GCodes
This class is fed GCodes, either from the web interface, or from GCode files, or from a serial interface, Interprets them, and requests actions from the RepRap machine via the other classes.
Heat
This class implements all heating and temperature control in the RepRap machine.
Move
This class controls all movement of the RepRap machine, both along its axes, and in its extruder drives.
Platform
This is the only class that knows anything about the physical setup of the RepRap machine and its controlling electronics. It implements the interface between all the other classes and the RepRap machine. All the other classes are completely machine-independent (though they may declare arrays dimensioned to values #defined in Platform.h).
Webserver
This class talks to the network (via Platform) and implements a simple webserver to give an interactive interface to the RepRap machine. It uses the Knockout and Jquery Javascript libraries to achieve this.
When the software is running there is one single instance of each main class, and all the memory allocation is done on initialization. new/malloc should not be used in the general running code, and delete is never used. Each class has an Init() function that resets it to its boot-up state; the constructors merely handle that memory allocation on startup. Calling RepRap.Init() calls all the other Init()s in the right sequence.
There are other ancillary classes that are declared in the .h files for the master classes that use them. For example, Move has a DDA class that implements a Bresenham/digital differential analyser.
Timing
There is a single interrupt chain entered via Platform.Interrupt(). This controls movement step timing, and this chain of code should be the only place that volatile declarations and structure/variable-locking are required. All the rest of the code is called sequentially and repeatedly as follows:
All the main classes have a Spin() function. These are called in a loop by the RepRap.Spin() function and implement simple timesharing. No class does, or ever should, wait inside one of its functions for anything to happen or call any sort of delay() function. The general rule is:
 Can I do a thing?
   Yes - do it
   No - set a flag/timer to remind me to do it next-time-I'm-called/at-a-future-time and return.
The restriction this strategy places on almost all the code in the firmware (that it must execute quickly and never cause waits or delays) is balanced by the fact that none of that code needs to worry about synchronization, locking, or other areas of code accessing items upon which it is working. As mentioned, only the interrupt chain needs to concern itself with such problems. Unlike movement, heating (including PID controllers) does not need the fast precision of timing that interrupts alone can offer. Indeed, most heating code only needs to execute a couple of times a second.
Most data is transferred bytewise, with classes' Spin() functions typically containing code like this:
 Is a byte available for me?
   Yes
     read it and add it to my buffer
     Is my buffer complete?
        Yes
          Act on the contents of my buffer
        No
          Return
 No
   Return
Note that it is simple to raise the "priority" of any class's activities relative to the others by calling its Spin() function more than once from RepRap.Spin().
