RepRapLinuxSoftware
Revision as of 05:17, 6 June 2007 by JonathanMarsden (talk) (version migrated from twiki)
Installing the RepRap software under Linux or Unix
RepRap uses a large number of open-source software packages for development, and quite a few when it runs. This page describes how to take a standard Ubuntu installation and prepare it for RepRap use. It then describes how to download and set up all the RepRap software. It should be easy to adapt the descriptions below for other Unix systems.
To do most of the following work it is useful to have two windows open on your computer:
  • A terminal window,
  • A web browser with this page displayed.
Note that for many of these installations you will need the superuser (root) password for your machine. You can copy-and-paste the commands below into the terminal window. Be careful what you run as the superuser, (or via su or sudo ) especially if you are not a Unix expert - you can damage your system with an ill-judged command... avoid typos.
In what follows, sudo is used whenever superuser priviledges are needed.
Java
RepRap's controlling software is written in Java, and also the Art of Illusion design package for three dimensional objects uses it, so next we need a Java development environment. The following method of getting one should be clean, in that it is easy to separate it from any Java that you already have on your system.
Note: You might as well install a full JDK not just the smaller JRE, in case you decide to help develop the RepRap software once you are familiar with it.
Java Development Kit (JDK) / Java Runtime Environment (JRE)
Install and configure the sun-java5-jdk package. Copy/paste the following commands into your terminal window (do not copy the leading =$= which represents the prompt from your shell!):
$ sudo apt-get install sun-java5-jdk $ sudo update-java-alternatives --set java-1.5.0-sun $ sudo update-alternatives --config java
If sudo asks you for your password, type it in! Now you have a working Sun Java version, ready to rock.
Java3D - 3D graphics in Java
The host RepRap software uses three-dimensional graphics to allow you to interact with the RepRap machine, so you need a copy of Java3D to permit that to work. Click on that link and download the appropriate file for your machine into your home directory; for Linux on a PC that file will be called something like java3d-1_4_0_01-linux-i586.bin. Note that, at the time of writing, Java3D version 1.5 does not work with the rest of the software, so you will need to click the previous versions link on the Sun site. Version 1.4.0.01 definitely works.
Then, cd to the Java run-time environment (JRE) directory, then run the downloaded file via sudo:
$ cd /usr/lib/jvm/java-1.5.0-sun/jre # This is your JRE directory, adjust if necessary $ sudo sh ~/java3d-1_4_0_01-linux-i586.bin
This will add extra files to your Java lib directory where Jave will be able to find them. If you have problems, check the README in the download folder, and see WhereIsMyJRE.
The j3d.org 3D utility library
There is an additional 3D utility library needed to be able to open and work with STL files. Download it from [1][here] using your web browser, and save it in your home directory. Then install it along with the Java3D .jar files (via sudo again):
$ cd /usr/lib/jvm/java-1.5.0-sun/jre # This is your JRE directory, adjust if necessary $ sudo cp ~/j3d-org-java3d-all.jar lib/ext/
RXTX Serial Library - serial-port communications
The host computer (that is, the computer on which you're installing all this software) talks to the RepRap machine using either an RS232 serial port (/dev/ttyS0 or /dev/ttyS1 on most machines) or via a USB-to-serial converter (/dev/ttyUSB0). Most laptops and some desktop PCs don't have a serial interface, so - if you have one of those - you will need to buy such a converter; they normally only cost a few pounds. (RepRap 2.0 "Mendel" will be driven directly via USB.)
Java, therefore, needs to know how to talk to these serial interfaces. Fortunately, there is a Java API that implements this.
RepRap now uses the RXTX serial libraries. The current version of them being used is 2.1.7-r2. Check the RXTX site to see if there is a newer one at the time you read this, and download the appropriate Linux binary .zip file, currently [[2]]. Save this file in your home directory. Now unzip the three files you need from it:
$ cd $ unzip -j -o rxtx-2.1-7-bins.zip rxtx-2.1-7-bins-r2/RXTXcomm.jar rxtx-2.1-7-bins-r2/Linux/i686-unknown-linux-gnu/*.so
Now (via sudo) copy those files underneath your JRE so Java will find them. In this example your JRE directory is /usr/lib/jvm/java-1.5.0-sun/jre. See WhereIsMyJRE.
$ JREDIR=/usr/lib/jvm/java-1.50-sun/jre # Use your own JRE location $ sudo cp -vp ~/RXTXcomm.jar $JREDIR/lib/ext/ $ sudo cp -vp ~/librxtx*.so $JREDIR/lib/i386/
Granting yourself permissions on your serial ports
Finally, ordinary users may not have access to the serial port(s) on your machine. So, add yourself to the dialout group (in Ubuntu), or (on another Linux distribution) take whatever other action you need to so you can access those devices.
{| border="1" |- $ sudo moduser -G `groups ||sed 's/ /,/g'`,dialout `whoami` |}
*Notes for Non-Ubuntu Linux*: A more manual approach is to edit your groups database by hand, perhaps by
$ sudo vigr -s
or similar. The moduser approach should work in both Debian and Ubuntu, and may also work in Red Hat based Linux distributions like Fedora and RHEL and CentOS. Serial port permissions are very distribution specific, so if you have issues with them, please read the documentation for your distribution carefully for clues.
RepRap Host Software
Now you are ready to download and run the RepRap Host software! Simply navigate to the SourceForge download page using your web browser, and choose the most recent version (0.8 as of writing). Download that, and then unzip it wherever you like (your home directory is fine). The easiest way to run it, is to double click the reprap-host.sh file and at the prompt, either select 'run in terminal (for debug text)' or 'run'.
Alternatively, you could run this command from the directory that contains the host software:
$ cd ~/reprap-host-0.8 # If you unzipped it in your home dir and are using version 0.8 $ ./reprap-host.sh
After a short load period, you will see this intial screen:
This is a representation of the build-base of the RepRap machine. You will load objects to be made here, move them to where you want them built, then build them.
For the moment experiment with the tilt, zoom and pan controls (left, middle and right mouse buttons respectively). There is a .zip file full of STL files you can load into your Reprap host software, downloadabe from Sourceforge. Some of the larger ones there will not yet "print" in your Reprap host software, though -- try out smaller the ones first.
Annoyingly, if you have an Nvidia graphics card on your system, a bug in the Nvidia drivers may become aparent here, and the software will give a Java exception rather than giving you graphics. To fix that, see here.
Congratulations!
You have now installed the RepRap Host software, and with the proper machinery, you are ready to get printing! This is just the surface of the software need to actually develop for the project. At this early stage, its unlikely that you will be able to get by with just the host software. Follow the instructions below to install and setup your complete development environment.
Development Software Installation
This is for the extra stuff that most people won't need. 3D modeling, circuit board layout/design, java compiling, firmware compiling, etc. Here there be dragons. As well as a lot of fun ;)
