RepRapMicron Delta mods
Revision as of 23:39, 18 March 2024 by VikOlliver (talk | contribs) (Implemented: Replace Pi)
//identifies pages under construction. remove when the page is relatively stable.
Creating A Micron Accurate Delta Stage
While the OpenFlexure Delta Stage is excellent for microscopy, it requires modification to become an R&D platform for μRepRap. There are a lot of unknown unknowns though, so it makes sense to push it as far as possible until we know what more of them are. A key difference is that microscopy is in 2D while μRepRap requires motion and observation in 3D. So rather than observing a slide from underneath, μRepRap needs to view the precision work area in several dimensions. Currently this is done by extending a beam from the slide platform which can reach a microscope stage.
Suggested modifications so far are:
Implemented
  • Replace OpenFlexure Raspberry Pi package with RAMPS system running GRBL
  • Improve robustness of motor mounts
  • Adaptors for NEMA17 motors
  • Extended beam to position probe over free-standing microscope
Unimplemented
  • 'O' Ring accessibility improvement
  • Mounting points to anchor stage to working platform
  • Illumination with different colours/directions to improve 3D visibility
Redesign
These are potential features for a redesign of the delta stage:
  • Integrate NEMA17 motor mounts
  • Some form of axis limit switch, or a hard stop
  • Alternative to 'O'-rings for backlash control
  • Proper solid beam to reach microscope stage
  • Anchor points for cameras viewing multiple angles
