RepRapPro Tricolour z axis assembly
Revision as of 11:05, 1 March 2013 by RhysJones (talk | contribs) (Created page with 'Next fit the belt to your X axis. Take the remaining belt, and insert the free end into the slot in the right end of the X carriage so that it locks with the teeth of the small l…')
Next fit the belt to your X axis. Take the remaining belt, and insert the free end into the slot in the right end of the X carriage so that it locks with the teeth of the small length of belt. It should ideally be placed as far into the slot as possible so that the end touches the edge of the narrow gap in the centre of the carriage. Then feed the belt through the X end Idler, around the small bearing, back through the carriage, around the motor pulley and back into the slot on the X carriage as shown below
