RepRapToolHeads
Revision as of 22:35, 30 December 2007 by ZachSmith (talk) (version migrated from twiki)
RepRap Toolheads
Thermoplast Extruder v1.0
This is the hot center of the machine. It can melt a variety of plastics and extrude them out in a thin stream to form a line. Put enough of these lines side-by-side end-to-end and you get a layer in a shape. Stack those up and you have an object. That's additive manufacturing, and it's the whole principle of RepRap.
Read more about the plastic extruder here.
Paste Extruder v0.1
The paste extruder will be used to extrude a variety of paste-type materials that can be used as structural support and for other purposes. It is currently under development so its design will change. But it works and it can be built now.
Read more about the paste extruder here.
Future Toolheads
There are many toolheads left to be developed. We still need lasers, metal deposition heads, milling heads, and all sorts of other heads taht have yet to be dreamed up. Check it out!
Read more about our future toolhead ideas.
