RepRap Firmware G-Codes
Revision as of 10:02, 18 March 2016 by PRZ (talk | contribs) (add 'new' indication)
The RepRap Firmware (abbreviated RRF) does use more G-codes than other firmwares notably because all configuration is done with G-Codes. Another reason is that it does have extended functionalities.
What is presently listed in this page is not the exhaustive list interpreted by RepRap Firmware, only the G-Codes which are specific (yet). This list cover DC42 and Chrishamm fork, which are more complete than the original version. Some G-Codes are common between RepRap Firmware and other firmwares, but with extended syntax or specific interpretation. They are listed in a specific paragraph.
Codes specific to RepRap Firmware
Macros and physical interfacing
Heaters
Ethernet communication
Miscellaneous Configuration
Web control (DWC)
Firmware configuration
Reporting - also used by DWC
Geometry
Miscellaneous commands
Specialised machines
G-codes with specific or extended syntax
