RepRap Firmware G-Codes
Revision as of 23:02, 21 April 2016 by PRZ (talk | contribs) (Useful G-codes)
The RepRap Firmware (abbreviated RRF) does use more G-codes than other firmwares notably because all configuration is done with G-Codes. Another reason is that it does have extended functionalities.
What is presently listed in this page is not the exhaustive list of G-codes interpreted by RepRap Firmware, only the G-Codes which are specific (yet). This list cover DC42 and Chrishamm fork, which are more complete than the original version. Some G-Codes are common between RepRap Firmware and other firmwares, but with extended syntax or specific interpretation. They are listed in a specific paragraph.
With RepRap firmware, everything is G-code
The RepRap Firmware philosophy is that every operation is done with G-code, notably all configuration, which is mainly stored in config.g file, called at board start-up. A set of standard or specifically crafted G-codes macros is written for all commons printer operation.
All G-codes or macros could be send to the board while operating the printer, allowing instant feed-back for any configuration modification. As interactive modifications are lost at next board start-up, the successfully tested G-Codes shall be manually introduced in the configuration file.
This interactive configuration makes the printer tuning easier than with other firmware.
Typical parameters
Most commands (M or G) are associated with parameters, typically Pnnn, Paaa or Xnnn. It shall be noted that the parameter qualifying letter is NOT part of the parameter, e.g. parameter PMyName is "MyName".
Commonly used parameter qualifiers are :
  • Pnnn or Paaa - Main parameter
  • Rnnn - other parameter
  • Snnn - other parameter, also often used to modify command behaviour (S0~S9)
  • Tnnn - typically Tool number, trigger number for M581 and M582
  • Xnnn, Ynnn, Znnn - parameter associated with an axis
  • Fnnn - feedrate
  • Hnnn or Hn:n:n - Height or Heater/sensor number
  • En or En:n:n - Parameter associated with extruder 0,1, etc. to 5
  • Dn or Dn:n:n - Hardware drive reference defaults are 0:X; 1:Y; 2:Z; 3:E0; 4:E1; 5:E2; 6:E3; 7:E4; 8:E5
  • Rn - enable value - for different hardware needing positive or negative signal to be enabled - M569
  • Bnnn - Safe printing radius (M665), baud rate (M575)
Sometimes a "-1" value is used to cancel a command.
It shall be noted that Extruder number, Tool number, Heater number and Drive number are separated entities which need to be associated one with the other. There are default associations between drives and movement/extruder axis.
Codes specific to RepRap Firmware
Macros and physical interfacing
Heaters
Ethernet communication
Miscellaneous Configuration
Web control (DWC)
Firmware configuration
Reporting - also used by DWC
Geometry
Miscellaneous commands
Specialised machines
G-codes with specific or extended syntax
Useful G-codes
