RepSnapper Manual:Installation
RepSnapper Manual
Windows Installation
- download RepSnapper.exe here
- run RepSnapper using RepSnapper.exe (you will need OpenGL)
Non-Windows Installation
Dependancy Installation
Although RepSnapper is not generally tested outside of window/linux/mac you may be able to get it running on other OS's. To do so you will need the following:
- gcc and stuff
- OpenGL
- SVN
- libfltk1.1
- libfltk1.1-dev
- libglut3
- libglut3-dev
- libboost1.37 and -dev (or higher version)
Linux
Debian/Ubuntu
To install the dependencies listed above on Ubunutu or any debian-based linux run the following from prompt:
sudo apt-get install build-essential libfltk1.1 libfltk1.1-dev libglut3 libglut3-dev libboost1.38-dev
OS-X
This page is a stub, you can help RepRap by expanding it
RepSnapper Download
You can download the RepSnapper source using svn here by running:
svn checkout http://www.kulitorum.com/RepSnapper/
RepSnapper Installation
Linux
cd Libraries/xml/ make cd ../../Src/ rm *.o ; make make
OS-X
