RepSnapper Manual:RepSnapper Howto
Revision as of 16:16, 20 October 2010 by MrAlvin (talk | contribs) (Print)
RepSnapper Manual
Basic Usage
Launching
Repsnapper main window
To run repsnapper on
  • windows: double click the repsnapper.exe file within the repsnapper/Src directory
  • linux: type repsnapper/Src/repsnapper into the console window.
  • OSX:
After launching the repsnapper application you are presented with the main window of the application
On the left is the 3D view and on the right is the configuration and control panel.
Loading an STL
To load an STL into the 3D view
  • click on the tab labeled Input file and
  • press the Load STL button. In revision prior to ??? you are presented with a Fluid file browsing dialog. In later versions you will be presented with your standard operating systems file browse dialog. Choose the STL that you wish to load and click OK.
The 3D view should now display your STL. Use this button to pull in a facet file to process into Gcode.
TIP: If repsnapper crashes at this point you might have an STL file that is "Bad Input" try converting it to binary using ./ivcon file.stl file.stlb and loading the binary version into repsnapper instead. you can get ivcon here. Compile using gcc -lm ivcon.c -o ivcon
Viewing the STL
Viewing STL in repsnapper
Once an STL is loaded you can rotate, translate and/or scale the view in the 3D viewer so as to see what the object looks like, doing so will not effect the print its mearly for viewing purposes.
  • To rotate the view of the STL hold down the left mouse button and drag.
  • To translate the view the STL hold down the left and right mouse button and drag.
  • To scale the view the STL hold down the right mouse button and drag, or turn the wheel on your mouse.
Note: the grid shows your build platform / printing area
Working with STL
Once an STL is loaded, you can move it to further onto the build platform, rotate it and scale it. You can also duplicate it and load additional STL files onto the build platform.
  • To move the STL, first select it on the browser, then tab to the translate box and enter absolute values into the X and Y fields. You can also drag the object by left-click-hold in the X or Y box then dragging it with the mouse. Apparently changing the Z value is not recommended.
  • Duplicate adds another copy of the STL beside the first.
Convert to GCode
Repsnapper displaying GCode
Converting to GCode is a simple process, click the GCode tab and press the Convert to GCode button.
If you like you can remove the homing and shield code from the next layer tab. This will save time between layers during prints, but should only be done if your machine is reliable and your steppers don't skip steps. Converts the STL model into GCode (machine language)
TIP: For a technical overview of the GCode generation read this
Print
To send the GCode to a FiveD GCode compatible printer:
  • open the Print tab, and
  • click the Connect to printer button.
  • Check the Communication Log tab to make sure the printer has connected and is receiving temperature signals from the Extruder Controller.
To start printing
  • click the Print button. This starts sending commands to the printer for execution.
This page is a stub, you can help RepRap by expanding it
