Risks
Revision as of 15:49, 4 January 2015 by Glenn (talk | contribs) (catchg)
Working Notes. Please log in and edit
Source
Plastic Toxicity
Raw
Re: Plastic recycler Posted by: Lionel (host86-160-66-209.range86-160.btcentralplus.com) Date: February 18, 2010 01:10PM
About plastic toxicity, thermoplastics are not toxic (as long as they are used well below their ignition temperature, of course, and as long as they are polymerised. Monomers are usually toxic). What may be toxic are the adjuvent: these are chemical added to the plastic to give it some additional properties. It can be antistatics, fungicides, lubricants, UV protectors, and so on. More documentation about them would be good in order to have a better idea of the risks, but for small amounts a well ventilated room should be enough.
Moderate: Delete•Delete + Replies•Split Here•Hide + Replies•Edit Options: Reply•Quote•PM•Follow Topic•Report Re: Plastic recycler Posted by: BeagleFury Date: February 18, 2010 01:35PM
Lionel Wrote:
> About plastic toxicity, thermoplastics are not > toxic (as long as they are used well below their > ignition temperature, of course, and as long as > they are polymerised. Monomers are usually > toxic).
Upon heating beyond a certain range, some thermo-plastics will decompose into dangerous chemical, the most common one being chlorine gas, which has a nasty habit of forming hydrochloric acid in your lungs when inhaled. This can happen even below ignition temperatures. Examples of plastics of this nature include PTFE, the material most commonly used as a heat barrier in the extruder. PVC may have some decomposition products, and definitely produces dangerous levels of HCl while combusting.
HDPE, PLA, and the other more common RepRap plastics should be fine, though I'd recommend not sticking your head over a combusting sample, just to be safe.
Extruder Flameout
Hypothetical
Wax
Utterly Dangerous
