SAE All-Metal Hot End
Revision as of 02:20, 20 November 2010 by Jgilmore (talk | contribs) (Found "taper pin reamer" for tapering the melt zone.)
These are good resources for creating wiki pages.
Very Messy Example and Columbus
--Sebastien Bailard 07:23, 10 September 2010 (UTC)
Example Development
Release status: unknown
documenting a generic tool/artpiece
I'm planning on making a Stainless Steel Hot End and of course I'm just going to go to the local hardware store which doesn't really have much in the way of metric stuff.
So I'm going to be drilling out my stainless bolt with a 1/8" drill bit. Do I need to get a 5/16" bolt or will 1/4" do? When I tap a 1/4-20 hole, I like to use a 13/64" drill bit, which implies that the wall will be 13/64"-1/8"=13-8/64=5/64" or about 1mm wall all the way around, less any eccentricity. Which I think should be enough, even given that I'll be using a drill press instead of a lathe. A 5/16-18 bolt uses a 17/64 tap size, which is 1/16 larger, or about 3.5mm extra, so 1.7 wall thickness under the threads, assuming an exactly centered hole. (which there will be, b/c I'll start the hole on that end.) That should be enough to ream?
if I want to ream it out to give a tapered hole, do I need to get a 5/16" bolt? Nophead's bolt was reamed almost completely out, I don't think I want to get that close, as I need to torque the acorn nut and aluminum heater block onto the end.
Do I need to a tapered hole? Nophead seems to think that tapered holes are just magic, and it's hard to argue with his results, so I'm inclined to say yes, I do need to have a tapered hole for reliable operations.
I suppose that it depends on the slope of the reamer. The reamer I found says 1/8" to 1/2", and the cutting edge is 3 3/4" long. My heater block is 1/2" thick. The depth of thread need for the acorn nut on the end will be greater for a 5/16" nut than a 1/4" one.
The length covered by the nut and heater block will be the molten zone, with the melt zone (which is what I'm trying to taper) just above that. So the tapered area should extend, say, 1/2" above there. So about 1 1/2" of tapered area. ~3/16" reamed out on the end of the bolt. Okay then, Looks like 1/4" is out, b/c 3/16>5/64. How deeply can a 5/16" bolt be reamed, assuming it's exactly centered and we touch the thread on the outside? Only ~3/4"! Something's wrong somewhere?
I'm trying to make the melt zone shorter, not the molten zone! I need to find a reamer with a lesser slope. I found one called a "taper pin reamer" and the one needed for this job is "2/0" size.
I'll use the taper pin reamer to add a taper to the melt zone, above the heater block.
--Sebastien Bailard 04:37, 19 November 2010 (UTC)
