SAE Prusa Mendel
Revision as of 23:04, 19 March 2011 by Julialongtin (talk | contribs) (use bolding better.)
Prusa Mendel
SAE Prusa Mendel is an offshoot of Prusa Mendel.
SAE Prusa mendel is an offshoot of the Prusa Mendel, only difference currently is it only uses 1 screw size (SAE #6 instead of metric M3 and M4), and only uses 608 bearings. Spacexula did the conversion, and is currently trying to maintain this branch.
<videoflash>tyVM3-v84I0</videoflash>
Development
The Prusa Mendel is on hosted github: http://github.com/prusajr/PrusaMendel
You can follow the changes on Changelog
You can sign up for github for free and fork the project to begin working on it.
History
Bill of Materials
The SAE Prusa Mendel BOM is slightly different than Metric Prusa Mendel, but as close as possible.
(in works, not complete yet)
Printed Parts
Quantity Description Type Comments Diagram
3 endstop-holder RP
12 pla-bushing RP-PLA check your build file, the file makes either 4 or 12 Pm-bushings.jpg
Non-Printed Parts ("vitamins")
Required
Quantity Description Type Comments Part Numbers
1 box (100) 5/16" nuts Fastener 95462A030 (1 box)
1 box (100) 5/16" washers Fastener 90126A030 (1 box)
1 box (100) #6 washers Fastener 90126A509 (1 box)
1 box (100) #6 1" screws Fastener 90272A153 (1 box)
1 box (100) #6 nylock nuts Fastener 90631A007 (1 box)
1 box (100) 5/16" Fender Washers Fastener 91090A111 (1 box)
3 608 Bearing Sets Bearings 5972K91 (?)
1 box (100) M3x10 bolt Fastener Motor Mounting 92005A120 (?)
2280 mm ~90"/7.5' Neoprene Belting .200" Pitch, 1/4" Drive Belt 7959K24 (?)
1 9 foot smooth rod (NOT GALVANIZED) X,Y,Z bars 8893K41 (3 foot sections)
1 21 foot threaded rod Frame 98841A030 (3 foot sections)
4 7/16" x ~1" springs optional, or from a spring loaded pen
1 Wade's Geared Extruder (or any other compatible extruder)
5 Nema 17 Stepper Motors
1 Standard Mendel electronics + endstops This can be RAMPS, Pololu Electronics, Gen6, Gen3, or anything else compatible
Aquiring Drive Belts
(No need to split belts, no continuous Z axis belt)
  Belt 1- 870mm ~34.25"/ 2.8'
  Belt 2- 1410mm ~55.5"/ 4.7'
Aquiring Smooth Rod
Do not get Galvanized Rods, they are much rougher.
Use Standard Mendel lengths for cutting 495x2 406x2 and 330x2.
The smooth rod is cut into varying lengths, therefore, its common to aquire in 3 foot sections.
If you have 3x 3ft smooth rod 8893K41
Rod1: 495mm,330mm                 19.5",13"  495mm seems too long on my build, try 5-7 cm shorter [-Bryan]
Rod2: 495mm,330mm                 19.5",13"
Rod3: 406mm,406mm                 16",16"
Aquiring Threaded Rod
The rods should be cut (by you) to the following sizes, in mm (the original sizes) or in inches for the SAE purist who wants to avoid little bits at the end.
To the right are "close enough" lengths in inches that will minimize number of cuts. (Note: Cut one of the threaded rod sets listed below, not all!)
If you have 3 ft lengths,
       Rod1: 440mm,440mm              18",18"
       Rod2: 440mm,370mm,50mm         18",15",2"
       Rod3: 370mm,370mm              15",15"
       Rod4: 370mm,294mm,210mm        15",12",9"
       Rod5: 370mm,294mm,210mm        15",12",9"
       Rod6: 294mm,294mm              12",12"
       Rod7: 370mm                    15"
At Lowes in my town you can get 4 ft length allowing you to combine Rod7 and 3 into 1, 4 foot rod, or you could use 3 four foot lengths and 2 three foot lengths for a less wasteful (and probably cheaper) set as follows:
       3' Rod1: 440mm,440mm              18",18"
       3' Rod2: 440mm,370mm,50mm         18",15",2"
       4' Rod3: 370mm,370mm              15",15",15"
       4' Rod4: 370mm,294mm,210mm        15",12",9",12"
       4' Rod5: 370mm,294mm,210mm        15",12",9",12"
At my local Menards or Ace Hardware 6 ft rods are cheaper than McMasterCarr (or anywhere else). Get three of them:
       6' Rod1: 440mm,440mm,440mm,370mm,50mm         18",18",18",15",2+"
       6' Rod2: 370mm,370mm,370mm,370mm,294mm        15",15",15",15",12"
       6' Rod3: 370mm,294mm,294mm,294mm,210mm,210mm  15",12",12",12",9",9" + extra
About the Electronics
The Prusa Mendel uses the 4 drivers in the standard Mendel electronics package to drive 5 motors by using "two steppers wired in parallel to one driver" [1].
Where To Purchase
See the Mendel Buyers Guide for information on where to purchase all of the parts needed.
Printed Parts
A printed set of Prusa Mendel parts
Printing a Prusa on a Mendel
An easier option then individually printing each part if you are printing Prusa on a RepRap Mendel is the pre-assembled build file containing the Prusa parts. With this option you only need to print the Mendel plate and the PLA bushings to get a complete Prusa Mendel:
Printing a Prusa on a CupCake CNC
There are also pre-assembled build files available to fit your CupCake CNC's build area (download using right click => save as)
Note:
  • These plates are 85x95mm in size.
Plates for the MakerBot (The plates have changed, these print times are no longer accurate):
Printing a Prusa on anything else
Last but not least, if you have a machine that doesn't fit into any of the previous options all the .stl files necessary to print a Prusa Mendel are available on the PrusaMendel Github where you can download them and print them individually.
Buy the printed parts
Mendel_Buyers_Guide#RepRapped_Parts_Kits
Assembly
Assembly of an SAE Prusa Mendel should proceed in exactly the same order as the original Prusa Mendel. Consult the Prusa Mendel Assembly Guide for more information.
Media
See Also
External Links
