Sandwich200
Revision as of 18:23, 6 April 2016 by Lkcl (talk | contribs)
Sandwich200
A fast, compact, folding, portable aluminum-framed CoreXY printer with a 200x200x200mm print area that folds into a 440x420x210mm box.
The Sandwich200 is a folding, portable CoreXY 3D printer that uses a 1515 aluminum extrusion frame. Capable of printing at high resolutions and high speeds owing to its CoreXY kinematics, it produces quality parts that are up to 200x200x200mm in size. In its assembled state it is 490mm high x 460 x 410mm (up to around 550mm due to the bowden tube); folded into its box it is 440mm x 420 x 210mm
Goal
To design a folding, portable 3D printer using CoreXY kinematics that offers high speed and quality. The printer must be able to be built without specialized tools, and must be completely rigid when assembled.
Features
  • Aluminum structure based on Makerbeam 15x15mm extrusion
  • Stacked variant of CoreXY that eliminates the belt crossing and its associated issues
  • Folds up into its own box, dimensions 440x420x210mm
  • Box halves are used when assembled to contribute to very good rigidity.
  • No risk of damage during transportation: Top CoreXY and Z Upright assemblies are totally separate from the box, which means that they can be packed in protective foam, away from the sides of the box.
  • 200x200x200mm build area with heated bed
  • All hardware and electronics (except for filament spool) are integrated within the frame.
  • Capable of 0.05mm layer height and 300 mm/s printing
  • Emphasis on using 3D-printed parts and being easily hackable/upgradeable
  • Geared bowden extruder, giving very high flow-rates (220mm/min - over 20mm3/s - before skipping occurs)
  • Low moving mass — all motors stationary.
  • No specialized tools or equipment necessary for assembly (accessible)
  • LM8LUU linear bearings used throughout, except in the Z-assembly which is dual LM8LUU plus LM8UU for huge (75mm) vertical bed support. Longer bearings means less judder, noise and wear.
Rigidity
Rigidity of the frame - despite the design essentially being four main parts - was achieved through geometric analysis prior to the build, and tested in cardboard (see videos). The two box halves are semi-rigid triangular wedges, with panels filling in the rectangular areas. For assembly, the two halves are hinged (not rigidly joined) in two places at the bottom to create a pair of "jaws" that sits upright. On their own, these "jaws" are able to flex and rotate about the z-axis. However: the Top CoreXY assembly specifically uses very strong folded-metal stainless steel triangular corner-braces that allow virtually no flex at all about the z-axis. Thus, when the Top CoreXY assembly is attached in four places to the top of the box, the entire assembly suddenly becomes as stiff as any regular non-folding 3D printer.
Bill of Materials
The BOM is maintained in the source for the CAD model, and is auto-generated (including an accurate count of nuts and bolts required). A copy is here: File:Sandwich200 bom.pdf
Printed Parts
The STL files are auto-generated from pyopenscad (included in the source). Obtain with git clone http://hands.com/~lkcl/foldable3dsandwich200/.git/ Build requirements: install git, GNU make, python2 and a recent version of openscad. run "make download" followed by "make".
Tools
Recommended: obtain a geared power drill or a screwdriver with a standard hexagonal toolbit adapter: there are an enormous number of M3 nuts, bolts and screws to assemble (over 300)
  • 1/4in socket (for M3 nuts. lots of M3 nuts)
  • Allen keys: 1.5mm, 2.0mm, 3.0mm, 4.0mm
  • Screwdrivers: electrical (for the EC), flat-head and/or pozidrive (for M3 screws)
  • M3 spanner(s), adjustable spanner(s), or Pincer-nosed pliers with small eye for nuts (M3) (Qty 2 recommended)
  • Another 3D printer capable of 0.20mm layer height (your own or use someone else's)
  • For cutting extrusions to length (from 1m Makerbeam): Metal hacksaw or 10,000 RPM disc cutter with 125mm x 1mm metal-cutting disc (*WARNING: Disc cutting tools are extremely dangerous: they can jump and kick out of your hand and send the metal flying off at high speeds*. If you have a Company Account, purchasing cut-to-order Misumi1515 is a much better idea)
  • Wood saw (if choosing MDF, Plywood or Hardboard for the box sides). Obtaining the panels cut-to-order is recommended (most iromongers / hardware stores can do this for you)
  • Soldering iron, solder, stand and sponge (usual deal for soldering)
Development
Discussion on the reprap forum is here: http://forums.reprap.org/read.php?397,639675,648097
Version 1.0
Initial variant. Uses a non-intersecting CoreXY design to eliminate belt crossing issues. 3mm Hardboard for the outer box keeps each box half rigid (no diagonal bracing needed). Folded steel corner braces from a hardware store keep the CoreXY assembly rigid.
Issues
  • Z-axis issues - pressing down hard on left side of the printbed causes right side to go up.
  • Untidy wiring
  • Huge number of nuts and bolts for the box (almost 100 to hold the panels in place)
  • Wing nuts stick out and often catch on nearby parts, making the printer harder to assemble and disassemble than it should be
Todo
  • Convert to 24V in order to increase speed without back EMF[1]
  • Resize uprights and reduce box size correspondingly.
  • Replace wing nuts with rotating, self-locking plastic parts (or spring-loaded "guitar-case" clips)
  • Add 2.8mm rail-runners to all parts (to fit into extrusion grooves), locking PLA parts in place.
  • Extend plastic parts where required so that no placement of any part requires measurements to be made during assembly.
Gallery
Videos
<videoflash>3n4vfIlU1B8</videoflash> <videoflash>KcDm6pHVeBo</videoflash> <videoflash>c2Yowf7puvQ</videoflash>
References
