Sanguinololu SD/fr
Revision as of 11:25, 30 November 2014 by Glenn (talk | contribs) (catchg)
Sanguinololu SD Adapter
Print designs from a MicroSD card on your Sanguinololu.
CC BY-NC-SA
Sommaire
Un lecteur de micro carte SD pour sa Sanguinololu - l'électronique de sa RepRap.
Où se procurer ?
La plupart du temps vendu déja assemblé, juste besoin de le brancher.
Printrbot.com: eMAKERshop: [1]
Montage sur la carte imprimée
Caractéristiques
Our design has fewer parts than others out there, can handle up to 100MHz clock rate should the need arise, and has built-in ESD protection as well. Here's the datasheet http://www.ti.com/lit/ds/symlink/txb0104.pdf. There's a LDO linear regulator on the board for the 3.3V SD supply. SD cards typically use about 80mA so we went with a smaller regulator than Kliment ( SDSL) used.
Pinout
1. Chip select
2. N/C
3. N/C
4. N/C
5. GND
6. N/C
7. DI/CMD
8. CLK
9. 5V
10. DO
Schéma
Compatibilité
Fonctionne bien avec Teensylu (by Steph the designer).
Mais ne fonctionne pas nativement avec RAMPS/Arduino Mega. Un adaptateur est nécessaire ou quelque chose comme sa.
Geek note: Gcodes that relate to the SD card here: [2]
Ce design est sous license : CC BY-NC-SA
Designer
Laine Walker-Avina designed this for use with a new printer design, the Printrbot [3] designed by Brook Drumm
--abdrumm 17:29, 4 November 2011 (UTC)
See Also
SDSL
