SinapTec
Revision as of 16:10, 18 May 2015 by Tatubias (talk | contribs)
SinapTec AT328.02
SinapTec AT328.02 is a 3D FDM printer controller board of very low cost, its operation is based on an Arduino Nano running a version of Teacup_Firmware. The board layout is designed so that it can be manufactured by any hobbyist, it is a simple face plate with through-hole components.
SinapTec AT328.02
Release status: Working
SinapTec AT328.02 3d printer controller board based on Arduino Nano.
Summary
  • 1 Arduino Nano socket.
  • 4 Pololus sockets (X,Y,Z y E)
  • 3 Line in for X_MIN, Y_MIN and Z_MIN endstops.
  • 2 Line in for Hotend and heated bed sensors.
  • 3 Mosfets outputs for Heater, Fan and Bed (this last with independent power supply).
Image Gallery:
Lista de Materiales:
Cantidad Codigo Descripción
3 IRFZ44N-IR TR. MOS-FET N-CH 50A 60V .028 E TO-220
3 CR25M-10E RESISTENCIA CARBON 1/4W 5% 10E
3 CR25M-100K RESISTENCIA CARBON 1/4W 5% 100K
4 CR25M-1K8 RESISTENCIA CARBON 1/4W 5% 1K8
2 CR25M-4K7 RESISTENCIA CARBON 1/4W 5% 4K7
3 L3R LED 3MM STANDARD ROJO 8MCD 60° DIFUSO
1 L3G LED 3MM STANDARD VERDE 8MCD 60- DIFUSO
1 1N4007 DIODO RECTIFICADOR 1A 1000V
2 10X50SR CAP. ELECTROLITICO 10 X 50V RADIAL (5 X 11 MM)
4 470X16SR CAP. ELECTROLITICO 470 X 16V RADIAL (8 X 14MM)
1 LM7805 REG. POSITIVO 5V 1.5A (10-220)
2 CER.1 CAPACITOR CER. DISCO 100NF X 50V Y5V (P=2.5mm)
5 B2P BORNE 2 POLOS APIL. 8A 300VAC AZUL
12 MJ2C MINI JUMPER CORTO 6.5MM (CERRADO)
1 TP 1X40 TIRA DE POSTES RECTA SIMPLE (1X40) .1"
3 TPHS1X40 TIRA HEMBRA P/POSTE P/C.I. (1X40) .1" STANDARD
Extra Files:
Firmware TeaCup_-_CoreXY:
PBC (Eagle)
PCB diagram for transfer toner
Gcode for drilling CNC:
Gcode for PCB CNC Milling:
