Skeinforge
Revision as of 15:11, 26 November 2011 by Glenn (talk | contribs) (catchg)
Example Development
Release status: unknown
documenting a generic tool/artpiece
PLEASE HELP US PACKAGE skeinforge for Debian/Ubuntu.
See http://www.debian.org/doc/manuals/maint-guide/ for general packaging instructions on Debian.
See https://wiki.ubuntu.com/PackagingGuide for general packaging instructions on Ubuntu.
See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=563369 for the current status of the packaging in Debian.
Skeinforge
Skeinforge is described [here]. It can be downloaded [here].
Skeinforge is written in the programming language Python. To run Skeinforge you will need Python. Python can be obtained [here.]. The official website for Python is [here].
Mr Kliment seems to maintain a (bundled) version that is Portable_Skeinforge
Note
Since skeinforge is a big part of the RepRap toolchain for a lot of people we may want to maintain a local mirror of it, along with incorporating all the tutorials. --Sebastien Bailard 18:57, 11 January 2010 (UTC)
Troubleshooting Tips
Extruder not moving
You need the dimensions module loaded to generate E codes, which drive the extruder.
Heater not heating when raft module disabled
The raft module also controls preheating. To stop printing rafts, simply set the layer-counts in the raft module to 0, rather than disabling it.
Extruder running backwards at start of print
Technically this is not a problem with Skeinforge, but you can make a simple change in Skeinforge to work around it. The issue is caused by manual extrusion (through RepRapHost, RepSnapper) prior to a print changing the E value calculated by your firmware.
To fix, in your start.gcode file add the command 'G92 E0' which resets the E count to 0.
Notes
The start.gcode should be in the directory ...\skeinforge_application\alterations where "..." is the directory skeinforge is installed in.
This file needs to be referenced in the "Name of Start File:" entry, under the "Name of Alteration Files" section of the "Preface" tab.
Volume-based extrusion
Skeinforge 040 made some drastic changes to the dimension module (for the better). Check here for help setting it up.
