Smartrap Build Manual
Smartrap Mini | How to Get Smartrap | Smartrap Build Manual | How to Use Smartrap | Smartrap Improvements
Welcome to the official document of the Smartrap's assembly.
This is the assembly manual for the Smartrap V 0.4.9 serie. For little changes between versions, we add extra steps.
Each step of building should take around one minute.
Tools you need:
- Small screwdriver plate for M3
- Bigger screwdriver for M6
- Allen key 1mm
Printed parts
plate_base 049 | plate_x 049 | plate_y | |||||
bottom 049 | endx_huxley | endx_back | |||||
glass_holder | glass_support | z_coupler 049 | |||||
direct_drive | belt_axis | belt_tensioner |
Updated parts 0.4.9.2
plate_base 0492 with integrated bearing support | plate_x 0492 with integrated bearing support | endx jhead lite with arm for mechanical switch | |||||
bottom 0492 : new form. | endy with window for gt2 tensioners |
Non printed parts
Pre-assemble the Huxley head 049
If you received a jhead lite, please jump this step.
1 | 2 | 3 | |||
4 | 5 | 6 | |||
7 | 8 | 9 | |||
10 |
Bottom / base
1 | 2 | 3 | |||
4 | 5 | 6 | |||
7 | 8 | 9 | |||
10 | 11 | 12 | |||
13 |
Y axis
1 | 2 | 3 | |||
4 | 5 | 6 | |||
7 | 8 | 9 | |||
10 | 11 | 12 | |||
13 | 14 | 15 | |||
16 | 17 | 18 | |||
19 | 20 | 21 | |||
22 |
Extruder
1 | 2 | 3 | |||
4 | 5 | 6 | |||
7 |
X axis
1 | 2 | 3 | |||
4 | 5 | 6 | |||
7 | 8 | 9 | |||
10 | 11 | 12 | |||
13 | 14 | 15 | |||
16 |
Z axis
1 | 2 | 3 | |||
4 | 5 | 6 | |||
7 | 8 | 9 | |||
10 |
Wiring
First , here is the electronics card mapping.
NOTES: if using a huxley , please use the D9 connection for the fan . If using a jhead lite, please use the two first pins of Zmax stop. It is used for +5v and ground. It will then turn to the right speed , always ( no need to control in software).
We use the most standard controler in the reprap world because you can find a lot of documentation about it : look for ramps 1.4 in your search and you will find tons of infos, forum, trics..etc.
1 | 2 | 3 | |||
4 | 5 | 6 | |||
7 | 8 | 9 | |||
10 | 11 | 12 | |||
13 | 14 | 15 | |||
16 | 17 | 18 | |||
19 | 20 | 21 | |||
22 | 23 | 24 |
Finishing
1 | 2 | 3 | |||
4 | 5 | 6 |
