Smartrap Build Manual
Revision as of 18:29, 26 October 2014 by Smartfriendz (talk | contribs) (Updated parts 0.4.9.2)
Smartrap Mini | How to Get Smartrap | Smartrap Build Manual | How to Use Smartrap | Smartrap Improvements
Welcome to the official document of the Smartrap's assembly.
This is the assembly manual for the Smartrap V 0.4.9 serie. For little changes between versions, we add extra steps.
Each step of building should take around one minute.
Tools you need:
  • Small screwdriver plate for M3
  • Bigger screwdriver for M6
  • Allen key 1mm
Printed parts
plate_base plate_base 049 plate_x plate_x 049 plate_y plate_y
Bottom.jpg bottom 049 endx_huxley endx_huxley endx_back endx_back
glass_holder glass_holder glass_support glass_support z_coupler z_coupler 049
direct_drive direct_drive belt_axis belt_axis belt_tensioner belt_tensioner
plate_base plate_base 0492 with integrated bearing support plate_x plate_x 0492 with integrated bearing support
plate_y endx jhead lite with arm for mechanical switch Bottom0492.jpg bottom 0492 : new form.
endx_huxley endy with window for gt2 tensioners
Non printed parts
Pre-assemble the Huxley head 049
If you received a jhead lite, please jump this step.
head 1 1 head 2 2 head 3 3
head 4 4 head 5 5 head 6 6
head 7 7 head 8 8 head 9 9
head 10 10
Bottom / base
base 1 1 base 2 2 base 3 3
base 4 4 base 5 5 base 6 6
base 7 7 base 8 8 base 9 9
base 10 10 base 11 11 base 12 12
base 13 13
Y axis
y 1 1 y 2 2 y 3 3
y 4 4 y 5 5 y 6 6
y 7 7 y 8 8 y 9 9
y 10 10 y 11 11 y 12 12
y 13 13 y 14 14 y 15 15
y 16 16 y 17 17 y 18 18
y 19 19 y 20 20 y 21 21
y 22 22
Extruder
y 1 1 y 2 2 y 3 3
y 4 4 y 5 5 y 6 6
y 7 7
X axis
x 1 1 x 2 2 x 3 3
x 4 4 x 5 5 x 6 6
x 7 7 x 8 8 x 9 9
x 10 10 x 11 11 x 12 12
x 13 13 x 14 14 x 15 15
x 16 16
Z axis
z 1 1 z 2 2 z 3 3
z 4 4 z 5 5 z 6 6
z 7 7 z 8 8 z 9 9
z 10 10
Wiring
First , here is the electronics card mapping.
NOTES: if using a huxley , please use the D9 connection for the fan . If using a jhead lite, please use the two first pins of Zmax stop. It is used for +5v and ground. It will then turn to the right speed , always ( no need to control in software).
We use the most standard controler in the reprap world because you can find a lot of documentation about it : look for ramps 1.4 in your search and you will find tons of infos, forum, trics..etc.
wire 1 1 wire 2 2 wire 3 3
wire 4 4 wire 5 5 wire 6 6
wire 7 7 wire 8 8 wire 9 9
wire 10 10 wire 11 11 wire 12 12
wire 13 13 wire 14 14 wire 15 15
wire 16 16 wire 17 17 wire 18 18
wire 19 19 wire 20 20 wire 21 21
wire 22 22 wire 23 23 wire 24 24
Finishing
finish 1 1 z 2 2 z 3 3
z 4 4 z 5 5 z 6 6
