Snappy
Snappy working | |
Snappy RepRap v1.1f | |
General | |
Description | A cheap, printable 3d printer that snaps together with almost no screws, rods, belts, or strings, and uses only one bearing. |
License | GPL |
Team Members | RevarBat |
Based-on | Sui Generis |
Files | GitHub |
Forum | Snappy RepRap Dev Forum |
Categories | Category:3D printers |
Machine Specifications | |
Current Version | 1.1f |
Dimensions | Length: 480mm [18.9"] Width: 530mm [20.9"] Height: 550mm [21.7"] |
Build Envelope | Length: 185mm [7.3"] Width: 185mm [7.3"] Height: 180mm [7.0"] |
Materials Printed | PLA, ABS with optional HBP |
Replication | By parts: 72% w/o cable chains, 79% with. |
Build Cost (≈) | US$292 |
Technology | FFF |
This article is about the Snappy RepRap 1.1f Printer.
PLEASE NOTE: This is the current home for community generated documentation (Please Contribute!). The official Snappy documentation is maintained at GitHub. Please refer to that site as well.
Overview
Snappy is an Open Source RepRap 3D printer designed by RevarBat from 2014 to 2015. It is a true RepRap, using very few non-printed parts. This design needs no belts, pulleys, metal rails, and almost no screws outside of the motors or extruder hot-end. This means that you should be able to put one together for under $300, including the price of plastic to print parts. The entire thing snaps together, and you should be able to assemble it from parts in only a couple hours. The few required non-printable parts are available world wide from a variety of suppliers.
Snappy is an original design, created in OpenSCAD, so many individual design parameters can be altered to fit the end user's specific needs.
You can see video of a prototype of Snappy version 1.1f running here.
Specifications
These specifications are for the Snappy RepRap 1.1f:
- Printed Parts: around 61 different parts, not counting cable chains.
- Non-Printed Parts: Motors. Electronics. Glass build plate. 2 ACME threaded rods. One 686 bearing.
- Printing Size: build area of about 7.5" x 7.5" x 7.5" or 19cm x 19cm x 19cm
- Material Cost: US$ 85
- Cost: Under US$ 300 (all parts, including plastic)
- Precision: about 0.05mm XY, 0.01mm Z
- Speed: 100mm/sec (position), 60mm/sec (printing)
Non-Printed Parts
The full list of non-printable parts for v1.1f are:
- 1 Power supply (12V, 120W)
- Controller electronics (RAMPS is cheap!)
- 3 Mechanical limit micro-switches
- 5 Stepper motors (NEMA17, 40mm long, 1.5A/phase)
- Wiring
- 2 ACME Threaded Rods, 3/8"-8 x 12"
- 1 Bearing (686)
- 2 Cooling fans (40mm)
- 1 Standard J-Head MkV extruder hot end
- 1 Extruder drive gear
- 1 Borosilicate glass build platform (about 200mm x 200mm)
- 4 Mini binder clips
Files and Documentation
- STL Files can be downloaded from the project's GitHub repository.
- A full Bill of Materials (BOM) is available at the project's Wiki.
- OpenSCAD Source Files are available at the project's GitHub repository.
- Assembly Instructions are also available at the project's GitHub repository.
