Spillski
//identifies pages under construction. remove when the page is relatively stable.
We spill beer so you don't have to. The name comes from another hobby, home brewing.
The Spillski will be a cartesian printer similar to the Eustathios, ProtoForge, and Herculien. [AluXY]
Release status: concept
[[image:|center|190px]]
Description | More to come.
License | CC BY-SA 4.0
Author | |
Contributors | |
Based-on | |
Categories | RepStrap, Laser Etcher, 3D printer
CAD Models | |
External Link |
Design Goals
The ultimate goal of this project is to have a very high print quality. Speed will be nice to have.
Most of the material will be metal, either aluminum or steal. Parts will be milled, but designed to be printable.
3-way Extuder similar to Richrap's design
Decisions made
It is controlled by the Smoothieboard.
It will have a bowden tube dual drive extruder from Bondtech and will have an E3D V6 hot end.
Will use 1.75mm filament
The base will be heated and move in the Z axis.
It will be enclosed and contain poly-carbonate windows with laser blocking tint.
It will have interchangeable heads to print and/or engrave
It will be CoreXY and be close to the AluXY design.
2-3W laser diode 445nM 9mm mounted in a module from DTR laser shop. The driver should be a Flexmod P3 (depending on backorder), and the encoder will be a DAC type setup similar to Dave and John on Hobby CNC forums. The L-cheapo was considered, but the design is either on or off and cannot vary the power levels.
Controller
The Smoothieboard can be purchased or assembled. Assembling the Smoothieboard is not the easiest for a novice due to the small SMD devices. If you choose this route, note that you will only save ~$25-$30 and some items will have to be re-spec'ed due to obsolescence. Everything can be sourced through digikey except the ethernet port (it has some strange pinout, and can be ordered through E-bay from China) and the play pause button (sparkfun cheap LED button). Also the step drivers require a reflow oven due to the heat sink pad under the chip and the ethernet IC has a ground pad under the IC. I was able to hand solder everything except the step drivers and the ethernet IC. Once the board is assembled the bootloader has to be flashed through the UART connector. After that reflashing is through the Micro SD card.
Designs
Designs along with BOMs will be posted on Github. Files will be generated using Solidworks and if needed AutoCAD. Other files will be MS Office 2013. Additional neutral formats will be generated i.e. pdf
Specifications and build instructions will be added as project progresses.
All dimensions are in inches. The conversion to metric will be considered. Sorry, the USA will probably never convert, and all of my tooling is in inches.
