Stepper Motors
Revision as of 20:45, 8 April 2010 by Wade (talk | contribs) (Suppliers)
Holding Torque
It is recommended that you get approximately 13.7 N-cm (that is 1400 g-cm or 19.4 oz-in) of Holding Torque (or more) to avoid issues, although one stepper with less has been used successfully (see below). If in doubt, higher is better. If you need to convert between different units for the torque you can use the torque unit converter here.
Stepping Angle
Most stepper motors used for a Mendel have a step angle of 1.8 Degrees. It is sometimes possible to use motors with larger step angles, however for printing to be accurate, they will need to be geared down to reduce the angle moved per step, which may lead to a slower maximum speed.
Size
If going for the smaller NEMA 14 motors, aim for the high torque option. NEMA 14s are neater, lighter and smaller, but can be hard to get hold of with the appropriate holding torque. NEMA 17s are quite easy to get in the specification that Mendel needs, but are bulkier and less neat. NEMA 14s are running near the edge of their envelope: they will get warm. NEMA 17s are well inside what they can do, and will run much cooler.
Note that any Mendel part that goes on to a Stepper Motor shaft expects the shaft to be roughly 5mm. If the shaft is a different size, you will need to make allowances for this in the parts you obtain/make.
Suppliers
Below is a list of possible suppliers and motors. Please add to it. If you have built a Mendel successfully with a given motor, remember to put true in the tested field.
Stepper Motors
Vendor (with link) Shipping location Manufacturer Model # Datasheet NEMA (Size) Holding Torque Shaft Tested Additional notes
Motion Control Products  ? Fulling Motor FL35ST36-1004B FL35ST36-1004B Datasheet 14 ~13.7 N-cm Dual true Used in mendel prototype
Active Robots UK Wantai 35BYHG04 35BYHG04 Datasheet 14 ~12.3 N-cm 4.9mm true Less Holding Torque than recommended, but has apparently been used successfully
Zapp Automation UK SOYO SY42STH47-1206A SY42STH47-1206A Datasheet 17 ~31.1 N-cm Single true None
Zapp Automation UK SOYO SY42STH47-1684B SY42STH47-1684B Datasheet 17 ~43.1 N-cm Dual true Round Ø5mm Shafts
Zapp Automation UK SOYO SY42STH47-1684A SY42STH47-1684A Datasheet 17 ~43.1 N-cm Single ? D-Shape 5mm shaft with 4.5mm flat
Interinar Electronics, LLC US Oriental Motors Vexta PX243M-01AA PX243M-01AA Datasheet 17 15 N-cm Single ? Not strong enough for direct drive extruder, Uses Imperial #4-40 TPI mounting holes instead of M3 metric
Alltronics.com US Lin Engineering 4218L-01-10 4218L-01-10 Datasheet 17 ~53 N-cm 3/16 inch = 4.7625 mm (Round) ? None
Alltronics.com US Lin Engineering 4218L-01-11 4218L-01-11 Datasheet 17 (?) ~53 N-cm ~5 mm = 0.1968 inches (D-Shape) true None
Phidgets.com US Wantai 42BYGHW811 42BYGHW811 Datasheet 17 ~47.1 N-cm 4.9mm ? None
SparkFun US Mercury Motor SM-42BYG011 SM-42BYG011 Datasheet 17 23 N-cm 5mm true None
Robot Gear AU Mercury Motor SM-42BYG011-25 SM-42BYG011 Datasheet 17 23 N-cm 5mm true None
Mindkits NZ Mercury Motor SM-42BYG011 SM-42BYG011 Datasheet 17 23 N-cm 5mm true None
AusXMods AU Rugao Xinhe 17H185H-04A  ? 17 ~43.8 N-cm  ? ? None
Pololu US SOYO SY35ST36-1004A  ? 14 ~13.7 N-cm 5mm ? Note: Pololu list this motor as 1400 g-cm AND as 20 oz-in (converts to 19.44 oz-in). According to supplier information, the metric value is correct.
Kysan China Kysan 42BYGH4803 Datasheet 14 49 N-cm 5mm ? Successfully tested with Wade's Geared Nema 17 extruder - high flow rates.
