Stepper motor controller SNAP protocol
Revision as of 14:04, 23 July 2015 by Glenn (talk | contribs) (+cat)
This page documents the SNAP Protocol stepper motor controller used in the Generation 1 Electronics and Generation 2 Electronics. For more recent G-code protocol stepper motor controllers, see stepper motor driver and list of electronics.
Stepper Motor Controller SNAP Protocol Version 0
This is the first version of the stepper driver command protocol, version 0. It communicates using the SNAP communication protocol, and accepts various commands for controlling both a single stepper controller, as well as doing coordinated movement with multiple stepper motors.
API
The following commands are in addition to the globally required commands on the main modules page.
[1] Set forward motion
Starts the motor turning indefinitely in a forward direction. If the motor reaches the maximum position sensor (as defined by the maximum optointerrupter input), motion will stop.
Parameters:
  • 1 byte: Speed to turn (0 to 255)
Returns:
  • Nothing
Notes: A speed of 0 will hold the current motor position. Use command [6] to power down the motor and let it turn freely.
[2] Set reverse motion
Starts the motor turning indefinitely in a reverse direction. If the motor reaches the minimum position sensor (as defined by the minimum optointerrupter input), motion will stop.
Parameters:
Returns:
  • Nothing
[3] Set position counter
Parameters:
  • 1 byte: low order byte of 16 bit position counter
  • 1 byte: high order byte of 16 bit position counter
Returns:
  • Nothing
[4] Get position counter
Parameters:
  • Nothing
Returns:
[5] Seek to position
Parameters:
  • 1 byte: Speed to move (1 to 255)
[6] Power down motor (torque off)
Powers the stepper motor down so that it can freely turn. This is accomplished by dropping the enable line and the four stepper outputs.
Parameters:
  • None
Returns:
  • Nothing
[7] Enable asynchronous notifications
Tells the stepper board to notify the host when it has reached the target for its mode (position, home, etc.)
Parameters:
  • 1 byte: address to notify (generally host)
Returns:
  • Nothing
Upon notification, the board will send a SNAP packet to the notification address that contains different data, depending on the type of notification.
Completion of rome/reset
  • 1 byte: 16 (home/reset command value)
Completion of calibration:
  • 1 byte: 9 (calibration command value)
  • 1 byte: low order byte of 16 bit maximum position counter
  • 1 byte: high order byte of 16 bit maximum position counter
Completion of seek:
  • 1 byte: 5 (seek command value)
  • 1 byte: low order byte of 16 bit current position counter
  • 1 byte: high order byte of 16 bit current position counter
Completion of DDA:
  • 1 byte: 11 (DDA command value)
[8] Prepare for synchronised movement
Parameters:
  • 1 byte: sync mode for the stepper motor. based on the table below:
Returns:
  • Nothing
Value Meaning
0 no sync (ignore sync pulses)
1 synchronized seeking (not sure if this is used)
2 incremental sync. move stepper forward 1 step each sync pulse
3 decremental sync. move stepper backward 1 step each sync pulse
[9] Calibrate
Initiates the calibration routine. This consists of seeking to home/minimum sensor, setting position to 0, then seeking to maximum sensor and recording the maximum position.
Parameters:
Returns:
  • Nothing
[10] Get motion range
Parameters:
  • 1 byte: 10 (get range command value)
Returns:
  • Nothing
[11] DDA; follow a co-ordinated line of motion
Starts a DDA movement where the X/Y axis move in a coordinated fashion to draw a straight line where they both start and stop at the same time.
Parameters:
  • 1 byte: low order byte of 16 bit master's target
  • 1 byte: high order byte of 16 bit master's target
  • 1 byte: low order byte of 16 bit slave's delta (which is abs(slave.current_position - slave.target_position))
  • 1 byte: high order byte of 16 bit slave's delta (which is abs(slave.current_position - slave.target_position))
Returns:
  • Nothing
[12] Forward a single step
Parameters:
  • None
Returns:
  • Nothing
[13] Reverse a single step
Parameters:
  • None
Returns:
  • Nothing
[14] Set motor power
Set the power output to the stepper motor. This is useful where output power must be limited to prevent damage to a motor. By default, for safety reasons, the driver starts in a low current mode. To enable full power output this function must be called first.
Note: This function has no effect if RB3 is not connected to the motor driver enable line (eg if it is held permanently on).
[15] Get raw sensor inputs
Primarily for debugging and diagnostic purposes, but possibly also useful for reporting.
Parameters:
  • None
Returns:
  • 1 byte: Response type (15)
  • 1 byte: PORTA inputs
  • 1 byte: PORTB inputs
Firmware
There are two different versions of firmware: older, stable firmware designed for the PIC16F648 and newer firmware designed for the Arduino. They both function identically, and accept the same commands.
PIC Based Firmware
The PIC based firmware is based upon each individual stepper controller board having its own individual PIC chip. Each board gets programmed with its own unique firmware. The three firmwares provide controllers on network addresses 2, 3 and 4.
PIC16F628 code images and source are available from SourceForge.
More information on the electronics required to process the commands is located at Generation 1 Electronics.
Arduino Based Firmware
The Arduino is a much more powerful microcontroller board based on the ATmega168, and we provide a firmware for it that emulates 3 individual stepper motor boards. From the perspective of the host software, it operates completely identical. The emulated controllers are on network addresses 2, 3, and 4.
Arduino firmware is available from SourceForge.
More information on the electronics required to process the commands is located at Generation 2 Electronics.
