Talk:WoodScrew Extruder
Revision as of 03:50, 10 September 2015 by KalleP (talk | contribs) (Retraction issues: new section)
Hi BEN1344,
If you have spare time for documenting your WoodScrew Extruder I would like to know more and to see some pictures.
Thanks. WilliamBoshi (talk) 15:59, 3 July 2014 (PDT)
Retraction issues
I think it may be difficult to get rid of backlash from the screw mountings when retracting unless it is rigidly coupled to the motor shaft. Even then the axial load is transferred to the motor bearings which are not specifically intended for end loading but could work if there was no play in the screw drive set-up.
KalleP (talk) 00:50, 10 September 2015 (PDT)
