Tantillus
Tantillus
Release status: experimental
Description | The portable self replicating mini printer
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Tantillus
Introducing Tantillus. The portable self replicating mini printer.
Status
Feb 27, 2012
- Alpha 1 is finished and printing. Geometric Object Deposition Tool Blog
- Beta 0.1 under construction.
Feb 9, 2012
- Alpha unit assembled and ready for testing.
Design goals
- Portable
- Self replicating
- Compact
- Fast
- Printable frame
- Expandable
Specifications
Outer dimensions:
- 200mm x 200mm x 300mm (225mm x 225mm x 300mm with reinforcements brackets installed, see picture)
Build Area:
- 102mm x 102mm x 120mm (100mm x 100mm x 110 usable)
Features
- LM8uu linear bearings on all axis (currently using Triffid Hunters printable LM8uu's for testing with excellent results).
- Fully printed case.
- It can print all of its own parts.
- Designed to use J-head hotend (eventually).
- Internally mounted extruder with bowden cable.
- External power supply to allow for battery operated use.
- Uses an interesting drive train: low cost wire rope (fishing wire) or High test Braided fishing line instead of costly belts (It wraps 5 times around the rod and then goes through a hole and wraps an additional 5 times resulting in no slip). This is a roll on roll off system with a fixed anchor in the middle.
Planned additions:
- Extension panels to allow it to expand itself by 100mm in any or all directions (incomplete as of yet).
- The ability to daisy chain two machines together to mass produce parts while only using one set of electronics (both machines would produce the same parts at the same time).
Printed parts
(All versions) 1 - Carriage top 1 - Carriage bottom 1 - Bowden clamp 2 - XY end (left) 2 - XY end (right) 1 - Z upper bracket 1 - Z lower bracket 1 - Z motor mount 1 - Z lift bracket 1 - Z coupler (set) 1 - Z arm (left) 1 - Z arm (right) 1 - Extruder body 1 - Extruder motor mount 1 - Extruder idler 1 - Extruder large gear 1 - Extruder small gear 2 - Axis drive gears 2 - Motor gears
(Additional for Laser cut version) 1 - Top 1 corner connector 1 - Top 2 corner connector 1 - Top 3 corner connector 1 - Top 4 corner connector 4 - Bottom corner connectors
(Additional for Printed version) 1 - Case top 1 1 - Case top 2 1 - Case top 3 1 - Case top 4 1 - Case middle 1 1 - Case middle 2 1 - Case middle 3 1 - Case middle 4 1 - Case bottom 1 1 - Case bottom 2 1 - Case bottom 3 1 - Case bottom 4 1 - Top front connector 2 - Top side connectors 1 - Rear lower connector 1 - Rear upper connector 3 - Middle connectors 3 - Base connectors 1 - Motor mount reinforcement 4 - Upper stiffeners
Vitamins
Count | Part |
4x | Nema 17 (max 42mm in length) |
11x | 608 skate bearings |
6x | LM8uu linear bearings |
2x | LM8suu linear bearings |
2x | 1 metre 8mm smooth rod |
1x | M8 x 100mm bolt (5/16" x 4") hobbed bolt |
4x | M8 nuts (5/16") |
1x | 250mm M6 threaded rod (1/4" x 6") |
2x | M6 nuts (1/4") |
70x | Socket head screws (Allen head) (sizes to be added when finalized) |
70x | Nuts for socket head screws (sizes to be added when finalized) |
20x | Washer for socket head screws (sizes to be added when finalized) |
16x | M3 machine screws for motors |
1x | 6mm x 188 x 188 acrylic or wood for bottom (could use thinner) |
1x | 6mm x 130 x 130 acrylic or wood for lower bed |
1x | 6mm x 130 x 130 acrylic, wood, dibond or aluminium for bed (could use thinner) |
10x | Zip ties to hold in linear bearings |
4x | M4 x 50mm machine screws for extruder (no6 x 2") |
8x | Springs for bed and extruder |
4x | Screws to attach bottom cover |
1x | RepRap compatible Electronics |
External Links
- First appearance of Tantillus
- Original blog post announcing Tantillus
- Attention since release
- Added to RepRap family tree (tentatively)
