Taurino
Revision as of 11:40, 6 May 2013 by RUMBA dancer (talk | contribs) (added direct link to open source files in reprapdiscount forum)
Template:Taurino
Taurino Power or Taurino Clasisc
Release status: Working
Taurino a 100% Arduino Mega 2560 V3 compatible device
Altium
Summary
Taurino is a 100% compatible Arduino Mega 2560 V3 board, it exists in two different versions, Taurino Power and Taurino Classic.
The Taurino Power is designed to run from 12V up to 35V powered thru the RAMPS shield. The Taurino Classic is designed to run with 12V from RAMPS shield. Both also work as Arduino boards powered thru USB.
Safety Tip
Once you start putting electricity into your RepRap - even at just 12 volts - you have to take basic, common sense precautions to avoid fires.
Just in case these fail, test your workshop smoke detector.
Got no smoke detector? Get one!
Taurino Power and Taurino Classic USB Driver for Windows
When you attach your Taurino for the first time to a Windows computer you might need to provide a driver (INF file).
Crystal Clear action run.png File:RRD-Taurio Power USB DRIVER.zip
Taurino Classic
Taurino Classic
Taurino Classic 100% Arduino Mega 2560 V3 compatible
Altium
Features
  • compact size: 108mm x 54mm
  • Arduino 2560-R3 compatible
  • can be used with 12V
Bootloaders
Original Arudino Mega 2560 V3 bootloaders are used
Source: Arduino bootloader
Taurino Power
Taurino Power
Taurino Power 100% Arduino Mega 2560 V3 compatible and capable of up to 35V
Altium
Features
  • ATmega16U2 (with enhanced firmware) for high speed USB serial connection (up to 2MBit)
  • UNIVERSAL POWER:
    • can be used with 12V-35V (e.g. RAMPS board with 24V can supply voltage (via D1) to TAURINO for standalone operation no damage of ATmega2560 possible due to to high power supply (e.g. from RAMPS or external connector)
    • integrated high precision power regulators 5V (ATmega2560/Logic)
ATmega 2560 STK500v2/Arduino2560 Bootloader
HEX: File:RRD-Taurino Power ATmega2560 ArduinoBoot.hex.zip
FUSES: E: 0xFD / H: 0xD8 / L: 0xFF
  • BOD=2.7V
  • ISP=ENABLED
  • BOOTSZ=4k
  • BOOTRST=ENABLED
  • EXTXOSC_8MHZ_XX_16KCK_65MS
16U2 LUFA/Arduino based USB2Serial Firmware
HEX: File:RRD-Taurino Power ATmega16U2 USB2Serial.hex.zip
FUSES: E: 0xF6 / H: 0xD9 / L: 0xFF
  • BOD=2.7V
  • ISP=ENABLED
Source: File:RRD-TAURINO SRC 16U2 FIRMWARE.zip (Atmel Studio 6 project)
Open Source Files
You can find the open source files here: http://forum.reprapdiscount.com/forums/oss/
