Taurino/fr
Release status: Working
Description | Taurino a 100% Arduino Mega 2560 V3 compatible device
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | Altium
External Link |
Introduction
La Taurino est une carte 100% compatible avec la carte Arduino Mega 2560 V3. Elle existe dans 2 versions différentes : la Taurino Classic et la Taurino Power.
La Taurino Power est conçue pour fonctionner de 12V à 35V via l'alimentation du shield RAMPS. La Taurino Classic est conçue pour fonctionner avec uniquement les 12V provenant de l'alimentation du shield RAMPS. Elles fonctionnent aussi toutes les 2 comme des cartes Arduino en les alimentant port USB.
Safety Tip
Once you start putting electricity into your RepRap - even at just 12 volts - you have to take basic, common sense precautions to avoid fires.
Just in case these fail, test your workshop smoke detector.
Got no smoke detector? Get one!
Taurino Power and Taurino Classic USB Driver for Windows
- NEW : Easy driver setup for Windows 8/7/Vista/XP 32 and 64 bit
File:RRD RUMBA TAURINO DriverSetup.zip
- CLASSIC: (can cause problems with Windows 8 and Vista/7 64bit, use the easy method from above instead)
When you attach your Taurino for the first time to a Windows computer you might need to provide a driver (INF file). File:RRD-Taurio Power USB DRIVER.zip
Taurino Classic
Description | Taurino Classic 100% Arduino Mega 2560 V3 compatible
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | Altium
External Link |
Features
- compact size: 108mm x 54mm
- Arduino 2560-R3 compatible
- can be used with 12V
Bootloaders
Original Arudino Mega 2560 V3 bootloaders are used
Source: Arduino bootloader
Taurino Power
Description | Taurino Power 100% Arduino Mega 2560 V3 compatible and capable of up to 35V
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | Altium
External Link |
Caractéristiques
- taille compacte : 108mm x 54mm
- ATmega16U2 (avec firmware amélioré) permettant une connection série USB high speed (jusqu'à 2MBit)
- ALIMENTATION UNIVERSELLE :
- peut fonctionner avec du 12V-35V (par exemple, la carte RAMPS recevant du 24V peut alimenter la carte TAURINO (via la diode D1) pour une utilisation autonome (sans avoir besoin d'une autre source d'énergie) sans endommager l'ATmega2560 à cause d'un possible survoltage (par exemple sur la RAMPS ou un connecteur externe).
- La Taurino Power possède des régulateurs 5V de haute précision (ATmega2560/Logic).
ATmega 2560 STK500v2/Arduino2560 Bootloader
HEX: File:RRD-Taurino Power ATmega2560 ArduinoBoot.hex.zip
FUSES: E: 0xFD / H: 0xD8 / L: 0xFF
- BOD=2.7V
- ISP=ENABLED
- BOOTSZ=4k
- BOOTRST=ENABLED
- EXTXOSC_8MHZ_XX_16KCK_65MS
16U2 LUFA/Arduino based USB2Serial Firmware
HEX: File:RRD-Taurino Power ATmega16U2 USB2Serial.hex.zip
FUSES: E: 0xF6 / H: 0xD9 / L: 0xFF
- BOD=2.7V
- ISP=ENABLED
Source: File:RRD-TAURINO SRC 16U2 FIRMWARE.zip (Atmel Studio 6 project)
Open Source Files
You can find the open source files here: http://forum.reprapdiscount.com/forums/oss/
Where to get it?
If you don't have the mood to build it yourself you can just buy direct from our ReprapDiscount Online Shop
