Temperature Chart
A table for predicting the temperature trends for a given configuration, versus material & color.
Use the "standard" thermistor placement from your hotend's instructions.
If possible, calibrate your thermistor or double check with another method of measuring (hard to do with many hotends).
If your hotend has other configurations or options specify which one(s) you used.
Be as specific as possible in identifying your material, at the very least specify the provider if not a specific blend number. For instance, Ultimachine provides a datasheet for 4043D PLA, but does not specify if this applies to all their PLA, while ABS is available in a huge assortment of blends, often not identified by anything but the name of the source.
User(s) / Printer(s) Hotend Make Diameter Barrel Nozzle Bed Surface Bed Temp. (PLA / ABS) Peak Speed Ultimachine Clear PLA 2.9 mm Ultimachine Black PLA 2.9 mm Ultimachine White PLA 1.75 mm Ultimachine Natural ABS 2.9 mm Ultimachine Red ABS 2.9 mm Vik's (diamondage) PLA 2.9 mm
(reported white, silver, trans. orange, fluor. orange, and purple)
Village Plastics Natural ABS Village Plastics Black ABS
DavideV / Prusa Makergear 3 mm 36 mm brass 0.5 mm brass "Bighead" glass (boro.) 60 C / 110 C 100 mm/s 185 C 185 C 210 C 210 C
Dust / Prusa Makergear 3 mm 36 mm brass 0.35 mm brass "Bighead" glass 60 C / - 100 mm/s 175 C
LoD / DC Extruder? Makergear 3 mm 50 mm brass 0.4 mm brass "Bighead" 225 C 200 C
kwixson1 / - Makergear 1.75 mm 36 mm brass 0.25 mm brass "Bighead" 65 mm/s 195 C
