Template:Delete
Revision as of 07:05, 5 April 2010 by Ebidk (talk | contribs) ("Marked for deletion" template.)
Standard deletion template
Usage: {{delete|reason}}
This page puts a bold red warning at the top of the page and adds the page to the Category:Candidates for deletion.
It should be added as the very first line on pages that you believe should be deleted from the wiki.
Example
This page or file is a candidate for deletion. The given reason is: No reason supplied!
This notice should remain for a minimum of 1 week after it was placed on the page. If discussion is still ongoing, it should remain until a consensus is reached, after which the page will either be deleted or this notice removed.
If you disagree with its deletion, please discuss your reasons on this page or on its associated talk page, as applicable.
Remember to check if anything links here and the page history before deleting.
Last edit by Ebidk (talk · contrib)
