Template:SCODE
Revision as of 15:05, 2 April 2021 by Ctkjose (talk | contribs)
SCODE
Creates an inline decoration for text representing code or keywords.
Example: Change the constant ENDSTOPPULLUPS in configuration.h and test with GCODE M119, connected to pin 52.
Other examples: Use 5V and GND or specify a value 12V
The first parameter is the text.
Optionally you can specify the named parameter type valid values are "gcode", "pin", "vcc", "gnd".
See other related templates: PIN, GCODE and NOTE
