Thermal
Revision as of 09:10, 2 October 2015 by Boy007 (talk | contribs)
Thermal
Release status: Stub
Laser Etching, Drill and 3dprinter
Attribution - Non Comercial - ShareAlike
idea's:
-vaneer sheet's, stanless steel pipe's as rail's, at proto parts MAHONGY tree but part's can be printed from ABS as well
-increase and stabilize object temperature while printing, this done fully closed system whit INFRARED heating, first test whit single 300W ceramic
-keep filament material's clean space
-active circulation of cooling and warm air + filtering inside and out, dust free printing
-collecting hazardouze gas and filtering it before release outside
-laser etching process for PCB prototype production
-drilling small hole's to PCB
-multi head printing
-my perosnal note's: [1]
First proto:
-work area 1000 x 500 x 500, effective work area about 980x480 , device 1000 x 2000 x 500
Motion's
-X linear open linear ball bearing two D=20mm rail's 1000mm
-Y linear open linear ball bearing two D=20mm rail's 500mm
-Z non linear "lab Jack style" elevating table, SFU1204 Ball Screw Ballscrew
-Z2 there will be fast speed Z movment at drill tool
-step motors: I'am testing suitability os Y NEMA17/extruders , X,Z axis NEMA23 2A-4A and difrent drivers
Electronics:
-four colour touch screen
-at proto mechanical switches, but real version hal
-IR temperature sensors sensing object temperature
-ULTRA SOUND collision prevention
-small line laser's to fast visual calibration of X,Y,Z trough USB CAMERA
Laser for etching:
-ideas development: [2]
-trying perhaps 500mw blue ?
-2W optically guided ideal but expensive
Firmware:
-open question, merlin or teacup or reprappro, i will start whit DUE and reprappro
Lab jack proto:
Building platforme chassis:
3 storage housing:
2:nd waiting chasis
my tidy electronics lab,.. there is allways project open:
Template:Extension
