Thermal Conductivity
Revision as of 05:03, 1 April 2011 by Xjcrawler01 (talk | contribs) (Various thermal conductivity of common materials)
While looking into insulating a hot-end and heated bed i found this information on the thermal conductivity of many different widely available materials. So I figured might be useful.
Original source Thermal Conductivity
Thermal Conductivity - k - W/(m.K) | |||
Material/Substance | Temperature - oC | ||
25 | 125 | 225 | |
Acetone | 0.16 | ||
Acrylic | 0.2 | ||
Air (gas) | 0.024 | ||
Alcohol | 0.17 | ||
Aluminum | 250 | 255 | 250 |
Aluminum Oxide | 30 | ||
Ammonia (gas) | 0.022 | ||
Antimony | 18.5 | ||
Argon (gas) | 0.016 | ||
Asbestos-cement board | 0.744 | ||
Asbestos-cement sheets | 0.166 | ||
Asbestos-cement | 2.07 | ||
Asbestos, loosely packed | 0.15 | ||
Asbestos mill board | 0.14 | ||
Asphalt | 0.75 | ||
Balsa | 0.048 | ||
Bitumen | 0.17 | ||
Benzene | 0.16 | ||
Beryllium | 218 | ||
Brass | 109 | ||
Brick dense | 1.31 | ||
Brick work | 0.69 | ||
Cadmium | 92 | ||
Carbon | 1.7 | ||
Carbon dioxide (gas) | 0.0146 | ||
Cement, portland | 0.29 | ||
Cement, mortar | 1.73 | ||
Chalk | 0.09 | ||
Chrome Nickel Steel (18% Cr, 8 % Ni) | 16.3 | ||
Clay, dry to moist | 0.15 - 1.8 | ||
Clay, saturated | 0.6 - 2.5 | ||
Cobalt | 69 | ||
Concrete, light | 0.42 | ||
Concrete, stone | 1.7 | ||
Constantan | 22 | ||
Copper | 401 | 400 | 398 |
Corian (ceramic filled) | 1.06 | ||
Corkboard | 0.043 | ||
Cork, regranulated | 0.044 | ||
Cork | 0.07 | ||
Cotton | 0.03 | ||
Carbon Steel | 54 | 51 | 47 |
Cotton Wool insulation | 0.029 | ||
Diatomaceous earth (Sil-o-cel) | 0.06 | ||
Earth, dry | 1.5 | ||
Engine Oil | 0.15 | ||
Ether | 0.14 | ||
Epoxy | 0.35 | ||
Ethylene glycol | 0.25 | ||
Felt insulation | 0.04 | ||
Fiberglass | 0.04 | ||
Fiber insulating board | 0.048 | ||
Fiber hardboard | 0.2 | ||
Fireclay brick 500oC | 1.4 | ||
Foam glass | 0.045 | ||
Freon 12 (gas) | 0.073 | ||
Freon (liquid) | 0.07 | ||
Gasoline | 0.15 | ||
Glass | 1.05 | ||
Glass, Pearls, dry | 0.18 | ||
Glass, Pearls, saturated | 0.76 | ||
Glass, window | 0.96 | ||
Glass, wool Insulation | 0.04 | ||
Glycerol | 0.28 | ||
Gold | 310 | 312 | 310 |
Granite | 1.7 - 4.0 | ||
Gypsum or plaster board | 0.17 | ||
Hairfelt | 0.05 | ||
Hardboard high density | 0.15 | ||
Hardwoods (oak, maple..) | 0.16 | ||
Helium (gas) | 0.142 | ||
Hydrogen (gas) | 0.168 | ||
Ice (0oC, 32oF) | 2.18 | ||
Insulation materials | 0.035 - 0.16 | ||
Iridium | 147 | ||
Iron | 80 | 68 | 60 |
Iron, wrought | 59 | ||
Iron, cast | 55 | ||
Kapok insulation | 0.034 | ||
Kerosene | 0.15 | ||
Lead Pb | 35 | ||
Leather, dry | 0.14 | ||
Limestone | 1.26 - 1.33 | ||
Magnesia insulation (85%) | 0.07 | ||
Magnesite | 4.15 | ||
Magnesium | 156 | ||
Marble | 2.08 - 2.94 | ||
Mercury | 8 | ||
Methane (gas) | 0.030 | ||
Methanol | 0.21 | ||
Mica | 0.71 | ||
Mineral insulation materials, wool blankets .. | 0.04 | ||
Molybdenum | 138 | ||
Monel | 26 | ||
Nickel | 91 | ||
Nitrogen | 0.024 | ||
Nylon 6 | 0.25 | ||
Oil, machine lubricating SAE 50 | 0.15 | ||
Olive oil | 0.17 | ||
Oxygen | 0.024 | ||
Paper | 0.05 | ||
Paraffin Wax | 0.25 | ||
Perlite, atmospheric pressure | 0.031 | ||
Perlite, vacuum | 0.00137 | ||
Plaster, gypsum | 0.48 | ||
Plaster, metal lath | 0.47 | ||
Plaster, wood lath | 0.28 | ||
Plastics, foamed (insulation materials) | 0.03 | ||
Platinum | 70 | 71 | 72 |
Plywood | 0.13 | ||
Polyethylene HD | 0.42 - 0.51 | ||
Polypropylene | 0.1 - 0.22 | ||
Polystyrene expanded | 0.03 | ||
Polyurethane foam | 0.02 | ||
Porcelain | 1.5 | ||
PTFE | 0.25 | ||
PVC | 0.19 | ||
Pyrex glass | 1.005 | ||
Quartz mineral | 3 | ||
Rock, solid | 2 - 7 | ||
Rock, porous volcanic (Tuff) | 0.5 - 2.5 | ||
Rock Wool insulation | 0.045 | ||
Sand, dry | 0.15 - 0.25 | ||
Sand, moist | 0.25 - 2 | ||
Sand, saturated | 2 - 4 | ||
Sandstone | 1.7 | ||
Sawdust | 0.08 | ||
Silica aerogel | 0.02 | ||
Silicone oil | 0.1 | ||
Silver | 429 | ||
Snow (temp < 0oC) | 0.05 - 0.25 | ||
Sodium | 84 | ||
Softwoods (fir, pine ..) | 0.12 | ||
Soil, with organic matter | 0.15 - 2 | ||
Soil, saturated | 0.6 - 4 | ||
Steel, Carbon 1% | 43 | ||
Stainless Steel | 16 | 17 | 19 |
Straw insulation | 0.09 | ||
Styrofoam | 0.033 | ||
Tin Sn | 67 | ||
Zinc Zn | 116 | ||
Urethane foam | 0.021 | ||
Vermiculite | 0.058 | ||
Vinyl ester | 0.25 | ||
Water | 0.58 | ||
Water, vapor (steam) | 0.016 | ||
Wood across the grain, white pine | 0.12 | ||
Wood across the grain, balsa | 0.055 | ||
Wood across the grain, yellow pine | 0.147 | ||
Wood, oak | 0.17 | ||
Wool, felt | 0.07 |
- 1 W/(m.K) = 1 W/(m.oC) = 0.85984 kcal/(h.m.oC) = 0.5779 Btu/(ft.h.oF) = 0.048 Btu/(in.h.oF)
