Thermocouple vs Thermistor
Revision as of 07:12, 5 February 2011 by Prusajr (talk | contribs) (Created page with '===Test comparing Thermocouple vs Thermistor=== I originally wanted to just calibrate the thermistor table I used in my FW, since I remember that Camiel from Mend…')
I originally wanted to just calibrate the thermistor table I used in my FW, since I remember that Camiel from Mendel-parts was moaning that his table was horrible and it affected his prints, I now just guess that his table wasn't made for his thermistor. I used one generated exactly for my thermistor by createTemperatureLookup.py from SVN. So I crated fake heater with both Thermocouple and Thermistor and written small sketch in Arduino to generate table, BUT I did want to simply try how imprecise it is. Then I was shocked, both readings were pretty close, actually biggest deviation was 3°C. You can see the graphs under and also download the Arduino sketch and sample data.
My verdict, is that both technologies are good for heaters and heatbeds, the precision is mainly affected by mounting on heater. Also be carefull to use precision resistors for thermistor circuits, thats all :-)
<videoflash>-_jajcG28M0</videoflash>
Files
Arduino code and data PDE CSV XLS Data .zip --Prusajr 12:08, February 5, 2011 (UTC)
