Threaded Pulley
Revision as of 08:02, 23 March 2010 by Casainho (talk | contribs) (Oh yeah, this is a great way to build our threaded pulley without a lathe, just a file, hand drill and 2 bearings :-))
Introdution
A threaded pulley is probably the best gear to use on extruder - see Geared Nema17 Extruder and NopHead test results. Example usage on Geared Nema17 Extruder:
There are a few ways to make a threaded pulley, using a lathe or witout a lathe.
Making a threaded pulley without using a lathe
Use a hand drill and a file to cut the slot, then hobbed it with an M3 tap mounted in the drill, using bearings mounted in a vise to let the bolt spin - see this videos:
Video using File:Pinchwheelwormdrilljig.zip.
Making a threaded pulley using a lathe
