TinyCut
Revision as of 13:10, 22 April 2014 by DavidCary (talk | contribs) (merge all text from Tiny Cut)
You might also want to look at Tiny Cut. Perhaps some or all of that page should be merged into this page. (Discuss)
Tiny Cut
Release status: concept
a transportable laser cutter
More details are available on the French language version of this page.
For our school project, we want to develop a transportable laser cutter. We are basing our work on the FoldaRap2 because we work in the same lab as Emmanuel.
Goals of this project: We want to develop this machine using off-the-shelves parts or existing projects and technologies. We want to be able, in this project, to create a tiny portable laser cutter in less than 4 months.
Concurrence
With 600€ you can purchase a small laser cutter
http://www.ebay.fr/itm/High-Precise-and-High-Speed-USB-CO2-Laser-Engraver-Engraving-Cutting-Machine-/170934801974?pt=LH_DefaultDomain_3&hash=item27cc821636
Specifications
  • Printed Parts: 20-21
  • Non-Printed Parts: Laser tube, laser PSU, optical parts, laser water cooling, air assist,
  • Cost: 400 € estimate
  • Cutting Size: 200mm x 200mm
  • Resolution : about ?? mm
  • Speed: ?? mm/s
This page has been flagged as containing duplicate material. An editor has suggested merging this page or section into TinyCut. (Discuss)
Tiny Cut
a tansportable laser cutter
Laser
The school project we want to develop is a transportable laser cutter. We base our work on the FoldaRap2 because we work in the same lab as Emmanuel.
Goals of this project: We want to develop this machine using off-the-shelves parts or existing projects and technologies. We want to be able in this project to create a tiny laser cut portable in less than 4 month.
Concurrence
Concurrence
With 600€ you go to an small laser cut http://www.ebay.fr/itm/High-Precise-and-High-Speed-USB-CO2-Laser-Engraver-Engraving-Cutting-Machine-/170934801974?pt=LH_DefaultDomain_3&hash=item27cc821636
Specifications
  • Non-Printed Parts: Laser tube, Power laser, optical part, laser water cooling, air boost,
  • Cost: 400 €
  • Resolution : a voir ?? mm and ?? mm
  • Speed: ?? mm/s
Special Features
  • Mobile!
  • Modular
  • Innovative
  • Based on standard/cheap 20x20mm aluminium extrusion (with 6mm slot)
  • Easy to build, with few tools (the printed parts are based on a 20mm grid (for overall aesthetic and mostly to ease the design), are generally 3-4mm thick, and fit the beams in a way you have nothing to measure during the assembly
  • Whith a real CO2 laser tube
  • Little (the entire machine is going to be about 30*30*30)
  • Big RED Power Security (my favorite detail ^^)
  • Cut surface about 200 x 200 mm
  • Easy to place on the material (it the machine witch go on the material, not the material witch go inside the small machine)
R&D
Our facebook
Inspiration
Some details that I found interesting or related or want to integrate to this idea of a portable laser cutter ...
External links, media/press, etc.
We like feedback from the community:
  1. marinosaurus page mention to be doing this project.
  2. User:Marinosaurus
History // forecast
  • 2013/02: beginning
  • 2013/03: Bills of materials, sourcing, buying
  • 2013/04: Developing CO2 and printing test, Receving the part.
  • 2013/05: Assembling work, and presentation of the project for our school.
Bill of Material Tiny Cut
Special Features
  • Portable
  • Modular
  • Innovative
  • With a real CO2 laser tube
  • Small (the entire machine is going to be about 300*300*300 mm) smaller when folded
  • Big RED Power Safety Switch (my favourite detail ^^)
  • Cutting area 200 x 200 mm
  • Easy to place on the work surface (the machine is placed on the material, not the material inside the small machine)
R&D
our facebook
Inspiration
Some details that I found interesting, related or want to integrate to this idea of a portable laser cutter.
History // forecast
