Tripodmaker
Revision as of 13:04, 13 April 2018 by Pj.vandendriessche (talk | contribs) (Print Results)
Tripodmaker
Release status: Working
Description End of life documentation for Tripodmaker.
License None
Author Pj.vandendriessche
Based-on None
CAD Models None
External Link none
Tripodmaker Stops its business
As of December 31st 2017 - Tripodmaker ended their production and support.
WE ARE SELLING OF OUR OLD STOCK
We have a limited ammount of devices left of our Tripodmaker v3.
Machine impressions
Prices and terms
  • Retail price: 2500 euro excl. VAT
  • Current price: 999 euro excl. VAT
  • If you order multiple devices, we might drop prices even further.
Terms for these devices:
  • No support
  • No service
  • No warranty
  • No shipping price included (please ask for a quote)
Interested in a device? Reach out to info[at]tripodmaker[dot]com with "BUY BLACK EDITION V3" in the title and we will get back to you.
SPECS:
HARDWARE
technology FDM (Fused Deposition modeling)
dimensions of printer 42 cm x 53 cm x 101 cm
print area Ø 25 cm x 42 cm
nozzle Ø 0.4 mm; full metal - up to 295°C
heated bed up to 100°C
power 88 - 264 V; 47 - 63 Hz; 5A
MATERIALS
diameter 1.75 mm
plastics PLA; PETG; HIPS; ABS; Polycarbonate
SOFTWARE
software Open source
PERFORMANCE
bed leveling full automatic; with possible screw assist
layer thickness / resolution 75 micron - 300 micron
machine tolerance 0.1 mm
Print Results
Check out our instagram here: TRIPODMAKER PRINT RESULTS
All support documentation can be found here.
Manual Tripodmaker Classic
Manual Tripodmaker Black Edition
Cura installation info for slicing
SET-UP PARAMETERS
Machine dimensions
dimensions Tripodmaker Classic Tripodmaker Black Edition Tripdmaker Black Edition with doors Tripodmaker Black Edition v2
X (width) [mm] 300 300 200 200
Y (depth) [mm] 300 300 200 200
Z (height) [mm] 390 450 450 420
Other specifications
  • Build plate shape: elliptic
  • Heated bed: checked
  • Machine center is zero: checked
  • Gcode flavor: Repetier
  • Printhead settings and Gantry height: Leave as is
  • Nozzle size: 0.4mm
  • Material diameter: 1,75 mm
Start code
;Home
G28
G1 X0 Y-100 Z030 F5000
;Prime the extruder
G92 E0
G1 F200 E30
G92 E0
End code
;Turn off temperatures
M104 T0 S0
M140 S0
;Retract the filament
G92 E1
G1 E-1 F300
G28 X0 Y0
M84
PRINT SETTINGS
Infill
  • Hollow: 0 percent
  • Normal: 10 percent
  • Strong: 25 percent
  • Solid: 100 percent
Material settings
materials ABS PLA PET Wood Flex 45 ASA
Volume flow 0,4 mm nozzle [mm3] 2,4 3,5 2,4 3 0,9 2,4
Volume flow 0,8 mm nozzle [mm3] 4,8 7 4,8 6 / 4,8
Print Temperature [Celcius] 255 215 230 215 260 260
Bed Temperature [Celcius] 90 60 70 60 0 90
Retraction Retract Speed [mm/s] 25 25 25 25 25 25
Retraction Prime Speed [mm/s] 25 25 25 25 25 25
Retraction Amount [mm] 2 3 3 3 0 3
Retraction Hop [mm] 2 0,075 0,075 0,075 0,075 0,075
Speed top/bottom [mm/s] 20 20 20 20 15 20
Speed bottom layer [mm/s] 20 20 20 20 15 20
Enable print cooling No Yes Yes Yes No No
Speed settings
Normal speed
These settings are the fastest possible settings to maintain a print that finishes for 90 percent successfully. Printing slower will result in better finish and better reliability.
Normal settings from Prisma are 60 percent of the fast settings.
Fast speed
Infill speed [mm/s] = volume flow [mmˆ3] / layer height [mm] / nozzle size [mm]
  • Outer wall speed [mm/s] = 0,6 x Infill speed [mm/s]
  • Inner wall speed [mm/s] = 0,6 x Infill speed [mm/s]
  • Speed top and bottom [mm/s] = 20mm/s
  • Support infill speed [mm/s] = 0,6 x Infill speed [mm/s]
  • Support roof speed [mm/s] = 0,6 x Infill speed [mm/s]
Example
PLA on 0,1 layer height and with 0,4 mm nozzle:
Fast Infill speed = 3,5 mmˆ3 (volume flow) / 0,1 mm (layer height) / 0,4 mm (nozzle size) = 87,5 mm/s fast speed Other speeds: 0,6 x 87,5 mm/s (Infill speed) = 52,5 mm/s
Normal Infill speed = 52,5 mm/s x 0,6 = 31,5 mm/s Other speeds = 18,9 mm/s
Additional Windows software:
Additional Mac OS X soft ware:
Netfab for mac:
Components to print
Trouble shooting
Calibration of your device
ATTENTION: DOING THIS WRONG WILL RESULT IN A BAD CALIBRATED DEVICE
Only Black edition models equipped with an inductive sensor can use this technique.
if you screw up, your device is lost and you are on your own
