UM v1.1 PCB Fix
Revision as of 20:34, 26 November 2011 by Glenn (talk | contribs) (+{{Deprecated|Ultimaker's v1.5.4 PCB}})
This page describes something which is no longer the most recent version. For the replacement version see: Ultimaker's v1.5.4 PCB
The batch of version 1.1 PCB had a small mistake. It creates a situation where indication LEDs for the MOSFET's will be 'always on', instead of when you turn the MOSFET output on. Luckily it's easy to correct it. Here's how:
These peninsula's should become real islands. Cross the three copper tracks that lead to them.
Here you'll need to do the same.
Above it the end result of isolating this part of the PCB.
When connecting the LED, instead of clipping the end of the lead, connect it to the one of the terminals as seen in the picture below. When done, the LED will only light up when you turn on one of the MOSFET's.
