User:EPoxi
Revision as of 12:05, 30 July 2013 by EPoxi (talk | contribs) (Created page with '''(From my original [http://forums.reprap.org/read.php?276,224676 post] at RepRap Usergroup - Argentina)'' I have a RepStrap (wolfstrap kind). The idea and original premise wa…')
(From my original post at RepRap Usergroup - Argentina)
I have a RepStrap (wolfstrap kind). The idea and original premise was to build it only with recycled and scrap materials (extracted from printers, etc). But, as I had some trouble with the homemade hot-end, I ended up buying one.
After several months of work, it was completed and functional.
In the following album you can see the step by step construction. Making of a RepStrap - Flickr
Technical data:
System Type .............. Cartesian with 3/16" threaded rods (22 turns per inch). Mobility made with drawer slides.
Engines .................. 4 x 7.5 ° 13ohm (savaged from HP printers)
Electronics .............. Arduino Mega 2560 + RAMPS 1.25 (Homemade)
Power Source ............. Vitsuba COL55 - ATX 550W (modified as laboratory source)
Extruder ................. Homemade, based on the "Simple sliced ​​Wade's Geared Extruder (thing: 8072)"
Hot-End .................. J-Head MKV (English Kit)
Heated-Bed ............... Homemade, based on Nichrome wire.
Maximum Working Area ..... 275x275x160
3D Printing Area ......... 200x200x160 (118.112 center)
Actual speed ............. 7.5mm / s (450/60)
Next steps: Iterate and make the needed parts for a Prusa i3.
