User:GorgHuff
Revision as of 08:50, 26 November 2008 by GorgHuff (talk | contribs)
Let's see if this works. Here is a hat rack / coat hook I did. I don't have a RepRap nor am I likely to in the near future not being mechanically inclined. But I can make 3D virtual objects and export them as stl files.
So if someone wants to try it.
File:Hatrack.stl
I tried it. I had to scale it down for my RepStrap machine as it is smaller than a standard RepRap. I also sliced the curved back off as it would otherwise have needed support material.
Thanks I changed the file to flatten the back and made the holes holes.
Here is a cup it may or may not work. I don't know if there are problems they will probably be with the handle. If I understood correctly it should be 120 mm tall.
I flattened the base of the cup angled the handle up a bit and added a support.
File:Cup03.stl
8 Sided die
D802.png File:D802.stl
