User:Jcollasius
Revision as of 18:13, 28 March 2015 by Jcollasius (talk | contribs) (Introduction)
JCollasius Knight Documentation
JCollasius Knight
Release status: in development
[[image:|center|190px]]
A cartesian XY/Z machine.
none
Introduction
The JCollasius Knight is a XY head type 3D printer, with easy to print parts and easy to gather parts. Developed in OpenSCAD its fully parametrical and can scale from tiny to huge build volumes. It uses aluminium t-slot extrusions for the frame. Every used part can be customized in the config.scad file to accommodate the available parts in your country. Since the belts must be very good aligned it's necessary to take exact measurements of some your BOM parts (if they are not standardized) like the pulleys and the belt. The 3d printed parts are build to fit your BOM, not the other way around. Keep that in mind. Since it is necessary to edit the config.scad to match your BOM there are not precompiled .stl files available. Build them with OpenScad as you need.
Dimensions
