User:Jfo5039/installingonwindows7
< User:Jfo5039
Revision as of 12:16, 13 January 2012 by Jfo5039 (talk | contribs) (Created page with '* Installed [http://www.python.org/download/ python] * Installed [http://sourceforge.net/projects/pyserial/ pyserial] * Installed [https://launchpad.net/pyreadline/+download pyre…')
I installed the four things in this order because this website told me to do so.
After installing all of that, I took the skeinforge profiles and alterations from here and put them into the skeinforge directory, overwriting the preexisting files. I should have backed them up in case shit fucks up.
Issue with connecting to the printer, hat do go into device manager to see what port it was. I set the data rate 19200 in pronterface in accordance with the guideline set on the whiteboard, changed the z speed to 60 and hit enter to confirm the change.
David gave me a copy of repsnapper which I used to interface with the white printer. It can be found here.
In this version, prior to printing, the settings were adjusted to numbers as seen here .
Made sure that the set temperature line in the Gcode window of repsnapper said "M104 S200.0".
Adjusted home of the z-axis in 1 and .1 mm increments so the tip was barely (.5 to .2mm) above the board.
