User:Jib5181
Blog Assignment 12
I dont think I would be interested in a printed figurine of myself. I would probably be a bit more interested if it were an action figure. Action figures could be make using similar technology, but would probably requre a bit more work, as the scanned model would need to be applied to a template for the moving parts. The details and color of the printed figurines from Japan are pretty impressive, espically with the overhangs required for printing the arms.
Blog Assignment 10
Additive manufacturing will become more common in industry in the future in the manufacture of complicated parts. As the process becomes cheaper, faster, more efficient, and resolution is increased it will begin to compete directly with parts made with conventional manufacturing processes. As the process becomes more common with a wide variety of materials, the use of printed components will become more common. The ability to adjust parameters such as infill will allow designers to get the desired mechanical properties in their parts with the smallest material cost possible. The ability to control the infill will make additive manufacturing very attractive to the aerospace and automotive industries where the weight of components are very important. Printing parts in their final shape eliminates the need for post-processing. When the cost of making a part using additive manufacturing becomes competitive with the cost of conventional manufacturing processes, which often require several steps between the near net shape and finishing processes, it will likely be as common as casting and machining are today.
Blog Assignment 9
I don't think the 3D printing systems we have would fit into a library, but would be a better fit for an open lab where students could come in and scan and print with the help of a TA, similar to the learning factory. This would require a stand alone room for the printers so they could be accessed at any time. Sharing 312 Hammond with other classes prevents our project from having this open door style lab described in the article. The rapid-prototyping machines at the learning factory operate at the per cubic inch of material that the university described in the article is beginning to implement.
If the goal of implementing a similar program would be to increase participation from students outside the College of Engineering, then a location in Patee/Paterno Library would be suitable. If the intent is to keep focus on printing for engineering classes, than a room in one of the engineering buildings on campus would be perfect for a print lab.
Blog Assignment 8
I think that the only type of system that this copyright system can be applied to is the 3D printer for personal use, such as the makerbot. The reprap community will likely quickly find a way around this print-blocking copyright software. 3D printer OEMs will likely include the software in their printers to prevent implication in copyright infringement lawsuits.
I still agree with my opinion from Blog Assignment 4 that this will only hinder the casual 3D printer user. If a similar system to music is put in place, some people may pay for the ability to print out certain parts, while others will search the internet for unrestricted copies or find ways to bypass the copyright protection.
I think that there can be some type of copyright protection of designs for printable parts. I think for it to work, it would have to be structured similar to what is currently used for the purchase of online music through itunes or zune. There would need to be an online marketplace that is compatible with the software used to operate the 3D printer. The integrating the two would be essential to ensure that the cop
Blog Assignment 7
1. The printed optical sensing devices would make 3D printing a viable option for creating entire electro-mechanical devices. Sensors could be directly implemented into the design of printed parts. While printing these sensors is likely much more expensive than purchasing optical sensors, improvements in the process will bring costs down. Eventually it will be cheaper to print the sensors directly into components rather than purchase the sensor separately and attach it to the printed component.
2. It is unlikely that our printers will be able to print light piping. The resolution required is much higher than our printers current capabilities. Also, the printers used in the video appeared to print the entire layer in one pass. This can be seen on the printed parts, as there is no visible extrusion path on the surface. There are also no visible layer boundaries. This is necessary for the transmission of light through the layers without a large drop in intensity. Some of these imperfections may have been removed in the post-processing shown near the end of the video. The only way that our machines would be able to print light tunnels would be for each tunnel to be one layer thick and exist on a plane parallel to the X-Y plane of the printed part. This would have to be done using a dual extruder capable machine, as the light transmitting material and and the material used for the rest of the part would likely be different.\
3. These sensors could be used to replace the endstops on our repraps. The endstops could then be integrated into the design of other structural components of the reprap. This would eliminate the problem of endstop misalignment.
Blog Assignment 11
I think 3D printing could be only implimedted at a high school level as a demonstration or something similar to the choose your robot project described here:http://www.3ders.org/articles/20120506-stemulate-learning-integrates-3d-printing-into-classroom.html . I dont think the development portion of our class would translate well to the high school level. The see it as it prints nature of RepRaps and Makerbots would are better for the classroom environment than the Stratasys machine descirbed in the third article. By letting the students watch the parts as they are printed, the limitations of what kind of parts can be printed are learned more easily. I'm not sure how we're running the demonstrations in teh EDSGN 100 classes, but if we could show parts printing to small groups of students, the number of unprintable parts would proabaly decrease. I dont think any high school level program involving 3D printing can succeed without the students watching their parts being made. Even if the high school students were only printing objects they had no part in designing, this would definately help create a greater intrest in engineering in those students.
Blog Assignment 6
1. Bio-printing is definately the next step in creating artificial organs. Because researchers can already generate most types of cells for any person, using bio-printing they may be able to arrange those cells into an organ. Printing an organ out of someone's own cells would prevent organ rejection in transplant patients. One possible problem would be getting the layers of cells to grow together to form one solid system. Another problem would be keeping the cells in the correct shape while they grow together. Something water soluble like PVA might be used for this, but it would have to have no residual effect on the cells.
2. The issue with extending this to repraps for DIY bio-printing is creation of printable cells affordably. Without access to bio-materials to print with, the reprap user has no need to outfit his machine to print bio-objects.
Blog Assignment 5
1. If I was a member of the DIY firearms project I would probably explore other options for 3D printing. RepRap would likely be easy for them to get without legal complications because of the off-the-shelf nature of most of the parts. However, the resolution of the printed parts from a RepRap is likely too low for this project.
2. 3D printing should not be regulated. However, the solid part files of dangerous objects, eg guns, shouldn't be allowed to be distributed.
3. If someone were able to print something that could act as a masterkey to any lock it would probably be frowned upon.
Blog Assignment 4
I understand why makerbot made a new closed-source model. They need to make a profit to stay in business. The Replicator 2 is much more expensive than what it would cost to build a prusa-mendel, so I don't see it as a direct competitor. For it to be worth the additional cost, the Replicator 2 must be much more reliable than the current generation of reprap.
As for moving our things away from thingiverse, if Makerbot does actually own everything submitted on thingiverse than it may be a good idea. However a suitable replacement for thingiverse should be found first.
Blog Assignment 3
1. Applying a DRM-type restriction onto printable objects will likely have a similar effect as it did to music and video files. It will only reduce use by people who have little knowledge of how to get around this restriction. If it were applied to printable objects today, it would likely have little effect. Because of the nature of current OS3DP machines, it takes a bit of technical skill to operate them. This means that it is likely that people who use and/or own a rep rap are familiar with 3D modeling software. Those familiar with 3D modeling will be able to re-create the printable object, without the DRM restriction. This will then be shared with other OS3DP users.
2. I'm somewhat passionate about advances in technology in auto racing. I find it very interesting and tend to spend too much time reading about it. It's something I like to talk about. I don't see this being of any help attracting a mate or getting a job.
3. I don't think 3D printing will be the undoing of intellectual property. 3D printing is not capable of replacing a large enough portion of the manufacturing industry to make this happen. Even if 3D printers are developed to be able to print structural metals, the printed pieces will not have desirable mechanical properties because of the layered nature of printing. This may be able to be overcome through an annealing process, but it is unlikely that the average 3D printer user will be capable of this.
1. Useful item: http://www.thingiverse.com/thing:1842
I printed one of these at the end of last semester. It works pretty well.
2. Artistic item: http://www.thingiverse.com/thing:11683
Definately Artistic, they never should have canceled Firefly.
3. Useless item: http://www.thingiverse.com/thing:27233
These gears look cool, but it's hard to picutre what could be driven with these.
4. Funny item: http://www.thingiverse.com/thing:7721
Someone made tailfins for their makerbot.
5. Wierd item: http://www.thingiverse.com/thing:11830
Printable baloon animal, definately wierd.
