User:Myassignmenthelp
Revision as of 01:21, 29 March 2019 by Myassignmenthelp (talk | contribs)
My Assignment Help - All you need to Know about Bibliography
Writing a bibliography at the end of any paper is essential to give proper credit to the authors whose works have been used in the paper. In any research work, it is necessary to write a bibliography as it helps in fact-checking. A bibliography also lets the readers discover more about the topic as they can refer to the resources for further information.
Including a bibliography may seem difficult in the beginning if you don’t know about the correct method. However, you also need to make the bibliography accurate to ensure that you don’t lose any marks.
In a bibliography, you need to list out the journals, books, online sources, magazines, which have been used in the research work. The bibliography must include all the sources that were used to conduct the research and not only the ones, which have been referenced in the text.
Here’s what you need to do to write a precise bibliography:
>> Learn about the what information goes in a bibliography- The bibliography will contain the author’s name, the full title of the source, the publisher’s name, publication date, page number. By knowing the components, you’ll have an idea about what data you need to collect from the sources.
>> Make a list to keep track- You should make a list of the sources to you are using in your research work. This way, you can keep track of them and don’t miss out any source while creating the bibliography. It is suggested to add to this list as you go along with your research.
>> Learn about the referencing style being followed- In different referencing styles, the bibliography is written in different ways. So, you should check which style you have been instructed to follow. According to that, you will write your bibliography.
Information to be collected
>> For printed sources 1.The name of the author 2.Publication title 3.In case of an encyclopedic or magazine, the title of the article 4.Publication date 5.Publication place of a book 6.Book’s publishing company 7.The volume number of a printed encyclopedia or magazine 8.Page numbers
>> For web sources
1.Names of author and editor (if available) 2.Page title (if available) 3.Organisation or company who owns the website 4.The URL or the page’s web address 5.The date when you accessed the page
Difference between works cited and annotated bibliography
In MLA, a bibliography is called the works cited page. In the works cited page, only the sources that were cited in the text are included in the works cited page. On the other hand, bibliography includes all the sources, which have been used while researching and also writing the paper.
The annotated bibliography is similar to a regular bibliography. However, it has a key difference. Following the citation, a brief evaluative and descriptive paragraph should be included while writing the annotated bibliography.
Examples of bibliographical entries in the MLA style and APA style are given below:
MLA- Dahl, Stephan. Social media marketing: Theories and applications. Sage, 2018. APA- Misirlis, N., & Vlachopoulou, M. (2018). Social media metrics and analytics in marketing–S3M: A mapping literature review. International Journal of Information Management, 38(1), 270-276. So, now that you know the essentials of creating a bibliography, you can write the entries using the required referencing style. You can also pay for essay online and get help with writing the bibliography.
